Do you have powerwalls or not? Inverters are typically programmed to monitor the power for 5 minutes after an outage or a glitch and once the power has been stable for 5 minutes they should come back online.
It seems unusual that yours would take 15 minutes to come back up, unless the power continued to be unstable. I believe that for a solar only install the inverter only reports it’s status every 15 minutes. So if you do have a solar only install then I’m wondering if the inverters are coming online after 5 minutes, but the app isn’t updated for 15 minutes.
As far as UPS’s go, they will also typically monitor the power condition for a little while before they switch back to grid power. 5 minutes seems longer than normal, but it’s not outrageously long. Some more advanced UPS’s will allow you to adjust this time, but most consumer grade units do not.
