Resetting "car needs service" error message
Discussion in 'Model S: User Interface' started by Trustno1, Jul 10, 2016.
  1. Trustno1
    Trustno1 Member
    Norway
    Hello
    I need an advice. I've just done an audio upgrade in my car that required me to remove the top trims on the dashboard. This also meant that I had to disconnect the airbag connector. The 12v battery was disconnected while doing this.
    When I did the install, I reconnected the 12v battery for a brief time to do some testing. Since this was while the airbag was disconnected, it triggered an "car needs service" error message, wich probably is normal.
    However when I reassembeled again, the error message still persists. Is there any way to clear the messages without contacting Tesla support? I've tried the usual reboots with scroll wheels and the upper buttons.
    Thanks for any help
  2. Trustno1
    Trustno1 Member
    Norway
    Well, this was quite embarrasing..
    I remembered later today that I also had disconnected a sensor on the 12v battery terminal when I disconnected the grounding cable. It turned out that this was the reason for the "car needs service" error message. When I hooked on this sensor, the message cleared automatically.
