Does anyone have a Powerwall 2 being fed by Skystream 3.7 (or any other) wind turbines as part of their own residential renewable energy system? We have a combination of wind turbines and solar PV with microinverters as part of our system.
Note: This feature currently requires accessing the site using the built-in Safari browser.
I don't see any problem as long as the wind turbines are grid tied and you can pass the circuits through the CTs the same way as the solar circuits so that the Gateway can measure the production. The turbines would also need to shut down or curtail when the micro-grid frequency shifts away from 60Hz.
Boy, what a setup. Are the other wind turbines your neighbor's? You don't seem to have nearby neighbors.
Agreed. The Skystream 3.7 specs only list UL 6142 Compliance. Assuming Skystream is connected to an UL 1741 compliant grid tied inverter, then it can unofficially work.
I think it is possible in the future for formal support, but Tesla currently does not formally accept wind as their app and system is not set up for it. Likely it is a lot of work to support 0.1%-1.0% of potential installations and regulatory restrictions.
It’s been an unusually breezy spring this year in Los Angeles...
If a grid tied residential turbine like the Skystream 3.7 were connected to a Powerwall like a PV array, would the PW software know the difference?
Likely no. This assumes the wind conductors are installed in tandem with an existing solar conductors though the measuring CT. One would have to accept the solar measurement in the Tesla app includes wind.
The issue is when the Powerwall is full. How does the gateway turn off the wind inverter when in backup mode? If it is UL 1741 SA compliant then no worries. If not, there may be a dangerous load imbalance.
"Skystream was granted UL certification for compliance with standard UL1741 / IEEE1547 after passing a series of tests. "
Southwest Windpower's Skystream 3.7 Gains UL Certification - Renewable Energy World
