Cyclone
Cyclonic Member ((.oO))
PS. It also suggests that Yobigd20, with about 4-5 drive units replaced so far, is a hard driver. Who would have guessed? LOL. Nothing wrong with that, of course. :smile:
Or is a high mileage driver!
The undersized bearing theory makes a ton of sense, but the much detuned Rav4 EV has the same problems. It's probably a bearing quality issue. Tesla started out with $ bearings which were crap, then they probably went to the next step which were $$, and so on. This is most likely another example where cheap becomes extremely expensive.This theory of failure suggests the bearings were undersized for the thrust loads, or perhaps a bearing manufacturing quality problem.
It also suggests that owners can prolong life by accelerating gently, with perhaps occasional hard acceleration events. Reality can often be more complicated, but this theory sounds likely, to me at least.
GSP
The fact is, I am the furthest thing from an aggressive driver. I never accelerate hard and just maintain an even flow with traffic. And mine is a non-P model. Yet I have the "milling sound" quite loudly and am waiting for my 3rd drive unit now. I'll defer to the experts here, but I still contend the sound seems "electrical" and not "mechanical" to me. I will definitely see if my Service Center can shed any light on the nature of the problem if/when they ever get me in.
That being said, the real world experience for owners is that around a magic 20k mile marker, something in the drive-unit is having issues. I had only narrowed it down to three issues as in my reading, I lumped together the milling noise and the drone above 65mph. But I will say the high-pitched buzz sounded a lot like a milling sound as it got progressively worse.
Another viewpoint to look at is if the above symptoms really do lead to catastrophic drive-unit failure. If not, then one could argue that if the symptoms are only aesthetic (still not acceptable), then a drive-train could make it to 500k miles, or 1 million miles, albeit noisily. But I doubt that's the case since the symptoms are a sign something in the drive-unit is undergoing a change from in-spec to out of spec.
The electrolysis bearing issue might be addressed by really expensive ceramic bearings, however maybe it is just more cost-effective to rebuild every 20-30k. I don't know. But there is a non-monetary cost to those rebuilds in the form of inconvenience to the owner that should be accounted for as well. Then imagine if it got out to the media that Model S requires a rebuild of the drive-unit every 30k? Or even if there was a suspicion that was the case. I mean, there goes your appearance of reliability in a superior drive-train and along with it, your stock price. It's no wonder they say they've found a fix.
I don't know what the solution is, but I agree we should allow for the possibility it hasn't been found yet; despite claims to the contrary over 2 years. The proof is in the pudding, and some owners are on drive-train number 4. You also have to realize that just because a new drive-unit comes out, doesn't mean the old stock gets thrown away. I think that is why we've seen early P85D's with failures. Tesla has to put them in something and it's easier to do a DU swap later than it is to write-off the loss of a part or rebuild it before it's even installed. They know we as owners will put up with it, so they do it.
This makes no sense to me. No drive bearing should have current running through it in any case. It's not like there are lightning bolts shooting around in there and the bearing gets in the way. The motor has windings that are completely enclosed.I thought I read in one of the threads on the sound that someone was told the sound is essentially both. Basically, the bearing will, over time, get some slop and this in and of itself doesn't cause the noise. However, this now provides and avenue for an electric arc across the bearing and this is what is causing the sound. Overtime the electrical arc over the bearing could lead to an eventual mechanical failure of the bearing. In that thread, there was talk about how this should be a ceramic bearing to avoid the potential for the arc.
I'm not a EE either, but I am a ME. Where did this bearing electrolysis data come from? I'd like to read more about it.Makes no sense to me as I'm not an EE. In my post I quoted one of the posts where the conversation of it took place. If I interpreted wrong in that thread, forgive me. I would love for that other conversation to be explained to me so I can understand better.
If there is a specific cause, only Tesla knows and they are not letting anyone else in on it. It could be a cheap fix or it could be catastrophic. The only thing we know that's true is that two of their prior explanations were b.s. If I remember correctly, one was that it was a loose wire that simply needed to bracketed down and the other was that it just needed a 50 cent shim. If either were true, there would be no repeat failures.
:smile:
Am I blind? I don't see a link. But I did find the thread with a search, and the only mention of "electrolysis" was his, and he did not give a source. Did he make it up?Follow the link in supratachophobia's post I quoted to that thread and see the conversation around his/her post.
Low Speed, High Pitch Whine
So yes, I am blind!When there is a quote, there is a blue "double-arrow" next to the person's name. That will take you to the actual post in whatever thread it came from. That is the link I was referring to.
So yes, I am blind!
I think that someone once posted that the milling noise was caused by current getting in, and going through the rotor bearings, thus wearing them. This is probably where the current iteration of the story came from.I'm not a EE either, but I am a ME. Where did this bearing electrolysis data come from? I'd like to read more about it.
I can tell you that in designing a mechanical system, I certainly wouldn't design something that relied on electrical current flowing through a bearing, or even allow that scenario to occur in a failure mode. Of course it's impossible to predict every possible failure mode, so who knows what could be going on that Tesla didn't anticipate. But I'd like to know more about this electrolysis theory, if that's what it is.
Agreed. Elon said this during an earnings call. None of my issues were related to anything being loose, and my service center even said that the droning noise is a bearing issue. This was long before the milling noise appeared. At least with all three of my DU replacements, none were for the reasons Elon mentioned in that earnings call. I, too, don't believe Elon's statements regarding this issue.
