The advantage of GCR is that minor or not, their stories go out on AP wires and often are picked up by other organizations. If nothing else it alerts news orgs to a story so they can write their own.
- - - Updated - - -
OMG. The car was a test article which was modified and inspected for purposes of the test. Just because someone forgets to bolt the seat back into place is not a reason to get upset.
If that's what happened, that's what happened. But I'd like to hear it from someone who actually knows rather than speculation from fellow (biased) enthusiasts.
Right now, all we know for certain is that the back seat detached and flew forward.
You are misunderstanding what I said. The interior of the car has large pieces of equipment installed for testing, including sensors and other materials (like crash dummies). Cables need to be run and other changes are made. Technicians spend a LOT of time inside of the car preparing them, and I've witnessed them removing seats from mini-van they were testing so they would have room to crawl around inside of the car.
This is concern trolling, pure and simple.
Here is a quick video showing some prep work that does not show seat removal, but note the large pieces of equipment being installed, and keep in mind that they needed to properly secure the test rig they put in the trunk and run cables to the front. So even in the video they are skipping a lot of the work they are doing inside.
Preparing Cars for a Small Overlap Crash Test - AOL On
Bottom line, it takes 2 or 3 minutes to remove seats and give yourself room to be comfortable while spending hours crawling around the interior. The idea that an nhtsa technician would forget to bolt the seat back in is about 10,000 times more likely than the idea that the armchair engineers in this forum have discovered a fundamental safety flaw.
And again, of all the car tests I've ever seen on the site (you can check yourself), none had this happen.
It's not about "discovering" a flaw. It's about seeing pretty clearly with our own eyes what happened: the seat detached and flew forward.
Why that happened? I don't know. I never claimed to know. But it's something that seems to be serious enough to warrant some explanation (whether it's oops, forgot to bolt it down, or oops, recall).
I could not agree with you more. NHSTA would not miss that problem. NHSTA is not populated by a bunch of fools. To think that "we" can out guess and out perform NHSTA makes some look foolish. TESLA is not "gaming" the system. To think otherwise is without merit.
My friend, I'd ask that you read what has been said. No one is saying that the NHTSA missed the problem, just that this problem, if it is indeed a problem, is not something that is tested by the NHTSA in the front crash test.
For the purposes of the front crash test, the back seat could explode, call down hellfire, make a mushroom cloud, disintegrate into ashes, and unleash demons, but as long as the front two passengers were not injured, it would get 5 star front safety ratings, because rear safety is not looked at in front crash safety ratings.
