I don't believe that one bit. The max at home charging speed is 11kw. If you are on a road trip and you stop at a super charger, you get 50kw-250kw. Now you're telling that a little slow 11kw charge at home is going to damage the battery? Really? You think that the battery get "too hot" from a normal drive? You think that the car has no way to regulate the temperature of the battery while driving to keep it at a good temp?
11kw is reasonably heat inducing, it causes raughly the same temperature as driving at 80kmh.
I guess this practice is also ideal to allow the car sleep within that period - with a view of allowing the car to take voltage readings at the low soc for better BMS accuracies.
My only concern with this practice was letting the car sit when its at a very low soc (5-10%) for a few hours.
There appears to be some views that you should not let it sit at these soc's for any amount of time, and ensure you get the battery back up to atleast 20%>.
Any thoughts on this? Or is 3 hours really no big deal at 5-10% before charging back up on AC at home?
Cheers
the OVC reading is at best a theory after some guys got some range back after letting the car sit at certain %. The same trick doesnt work for a lot of other people. There isnt really much evidence that the car needs to sit at anything but 90%.
We dont have much evidence that sitting at low SOC is harmful for the battery. Tesla recommends against that practice but equally a lot of manufacturers actually recommend storing their lithium ion cells completely discharged at sub 0C.
I would guess that the battery is least stressed at around 40-50%, however I couldnt really find any data for capacity loss when stored at below 40% though I suspect it is going to be less than when sitting at 90%....
