I've had this on my first ever charge of a brand new M3LR, collected from Heathrow on Tuesday. Plugged it into a Source London 7kW charger on Thursday night, with charging commencing probably at 7kW and 32A, but then after about 30-40 minutes (and probably at around 9.00pm?) dropping to 4kW and 16/17/18A. I didn't disconnect and reconnect at the time, as we were trying to take advantage of the 4-hr overnight cap and didn't want to restart the window and (not yet having come across this thread) I wasn't sure whether this was an issue with the Source London charger, but now it looks like that will be the solution until the fix is rolled out.
For those who have had luck overcoming this by disconnecting / reconnecting, does it look like a physical disconnect (or a re-start of the charge from the charger end) is required? Or might it suffice to stop and restart charging from the M3 only, e.g. via the app? That would at least mean that the 4-hr overnight cap would not have to be broken...
I've seen a few suggestions in this thread that reducing the charge current in-car and then increasing it again back to 32A might fix the problem. I'll try that next time too.
