Had a text from Tesla service about it too and tried to explain by reply as best I could!Just had a call from the service centre asking about my charging issues and for dates & times when I started a charge and had the issue. It will be passed on to the technicians to look at the logs. He said they have had a few reports of this so far.
Worth submitting a service request if you have the problem and keep a note of your charging start and end times in case they ring.
Same here - this is a serious issue tbh.There we go.
Happened to me last night. It’s interesting that it seems stuck at 17A now, whereas before it was 16.
Anyway, a service request has been submitted and I have an appointment for the 8th of July.
Disappointed, one of the big things that differentiates Tesla from the rest is their software and to see this kind of sloppiness makes me worry about the quality of the the coding in their safety-of-life subsystems...
To be fair, I logged a service request around 1am and had a phone call from Tesla Energy this morning at 0830 asking for more details so they can look at the logs.Same here - this is a serious issue tbh.
I plugged in last night and at 32amps it would have finished by the time I was up this morning. But it had cleared dropped to 17amp at some point as when I woke up it still wasn't done and needed another 1.5 hours.
Fortunately I didn't need to go anywhere immediately. But if someone has planned their (regular) journeys on the basis of being able to recharge fully in a certain timeframe this could really interfere quite a bit!
Ok so been keeping an eye on my charging as i don't have teslafii to monitor fully, but know my SR+ usually can charge just over 50% and remain in my 4hr window of octopus, last night charge started at 0:30 at 50%m and didn't get to my preset 90% until 5:26, so just under 5 hours to get 40% charge, clearly not charging at maximum rate, and crept into my 'expensive' rate.
Well, I talked that up...I’ve never altered the charge setting in the car and despite 2020.20.12 and I’m charging at full whack of available solar (circa 7.1 Kwh)
Mm. The last charging bug took months before it was fixed!Maybe we should all start tweeting Elon. After all an electric car that isn’t charging properly is a fundamental issue that needs to be fixed pdq.
Can’t be hard to do a code diff between last release and this one to see what’s been changed that will affect the charging rates. Then fix and new release.
Nobody writes bug free code, so the issue is not about there being a bug, its how you respond to it that matters, ie be open and communicative with your customers and fix as soon as practical / safe / retested.
(Admission: I run a software team!)
