Reus Audio Upgrade Completed!
Discussion in 'Model S: User Interface' started by EMDoc, Jun 7, 2013.
  1. EMDoc
    EMDoc Member
    San Diego
    If anyone is interested in updating the std or studio sound audio, I can fully vouch for Reus in Orange, CA. Just got the car back and I don't feel like getting out of it! It sounds better than any other audio system I've heard and honestly feels like a concert/club. You have to see the demo at the store that is difficult to argue with comparing their own speakers vs "top end" speakers. Quite an amazing shop and I'm more than pleased with the sound. The equalizer is now zero'd out but sounds astounding!
    Just thought I'd add my two cents in case anyone is on the fence! This was an upgrade worth every penny! The best part is, the car appears completely stock!
  2. ken830
    ken830 Model S (Res#P12,447)
    San Carlos, CA
    Did you start with standard or studio sound? If standard, did your upgrade include the speakers in the rear hatch?
  3. EMDoc
    EMDoc Member
    San Diego
    Ken - started out with studio sound. The upgrade includes upgraded tweeters in front and an additional center channel. I had them replace the 8inch sub with their 8 inch. Did not replace speakers in hatch...and don't even need to. The sound stage is fantastic and immersive. Oh and they added a separate amp for the sub.
  4. spatterso911
    spatterso911 MSP#7577 **--** MX#1891
    Rancho Cucamonga, CA
    I can second that vouch! It's a dramatic upgrade.
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I'm sure it doesn't but no effect on the Model S warranty? I may look into this as well. Thanks.
  6. bigsmooth125
    bigsmooth125 Member
    United States
    EMDoc, can you state what the price was?
  7. EMDoc
    EMDoc Member
    San Diego
    About 3600. discounted a bit in a semi group buy.
  8. FredTMC
    FredTMC Model S VIN #4925
    Orange County CA
    I only have std sound and it sucks pretty bad. So, they'd add more speakers than your studio upgrade, I assume.
  9. swegman
    swegman Active Member
    They have 5 different systems. Which one did you get?
    My understanding is that they equalize the audio. What happens when Tesla modifies the studio sound system equalization via their firmware updates? How does that effect Reus's calibration? I asked them but did not get a satisfactory answer.
  10. EMDoc
    EMDoc Member
    San Diego
    I believe for the std they upgrade front speakers, add tweeters, and the sub in the factory location.
    As for support after firmware updates, I find that Reus is like Tesla in that they cover you for the life of the system/car. I'm not too worried about going back to get "adjustments" made. It does depend how easy that would be for you if you live farther away...
  11. swegman
    Jeff Coles (he goes by the name kickgas over at the Tesla motors forum (Tesla Motors | Premium Electric Vehicles) under the Washington, DC section) is attempting to arrange a group buy for the Reus Audio system they have developed for the Tesla model S. I have spoken to the company and obtained the following information about their audio upgrade for the car.
    Below are brief descriptions of the 4 systems that are currently available for the car, along with a 5th system (referred to by Reus as the audiophile version) that is under development and which they hope to have available in a couple of months.
    Reus has indicated to me that each of their systems are blueprinted from the ground up with every aspect of the Model S taken into consideration from its acoustics as well as vehicle integration, with no permanent or visible changes being made to the car. A dedicated system has also been designed for vehicles that are fitted with the third row seats. Reus asserts that all of the active system parts are compatible with the vehicle’s software and electronics.
    System 1 (Entry Level System) - Target price around $3,000
    The entry level system is a fully engineered design specific to the Model S. The audio interface and all harnesses are fitted to the S architecture. The factory woofer is replaced with a new 8" woofer that is reportedly designed to match the acoustical properties of the Model S and the new amplifier that Reus has designed for this vehicle. The factory supplied tweeters (located in the pillars next to the windshield) are replaced with dual wide dispersion upper midrange tweeters. Reus asserts that these are the most important speakers in the system and carry over 50% of the system’s musical impact. The lower door speakers provided by Tesla are retained, but reportedly are noise shaped to work efficiently within their limits and integrate with the new speakers (installed in the pillars next to the windshield) in perfect phase. An additional small front speaker is added by Reus to reportedly enhance the front soundstage across the dash. Both electronic and passive crossovers are installed by Reus. Audio power is increased by an additional 400 watts RMS by an additional amplifier that Reus installs. An optional woofer control (cost unknown) is available, which Reus recommends if one has multiple music file formats where the level of compression varies to a great degree. Reus indicated that the optional woofer control is not required if the music file format is are consistent (i.e., all the music files are of one type, such as FLAC or MP3).
    System 2 - Target price $3,700
    A 10" woofer module is added to work with the factory woofer (a different design is used for vehicles not fitted with the Tesla Studio Sound system). The factory supplied tweeters are replaced with dual wide dispersion upper midrange tweeters, as noted in System 1. As in System 1, an additional small front speaker is to reportedly enhance the front soundstage across the dash. The same technology applied to System 1 relative to the door speakers applies to System 2 as well. Crossovers are added which are both electronic and passive. Power is increased by an additional 500 watts RMS above the Tesla system) by a Reus designed and installed amplifier. As with system 1, an optional woofer control is also available.
    System 3 - Target price $4,100
    A 10" woofer module is added. In addition, the Tesla factory woofer is replaced with a new long throw 8" design woofer (a different design is used for vehicles not fitted with the Tesla Studio Sound system).
    The factory supplied tweeters are replaced with dual wide dispersion upper midrange tweeters. An additional small front speaker is added to reportedly enhance the front soundstage across the dash. The same technology applied to System 1 relative to the door speakers applies to System 3. Both electronic and passive crossovers are added. Power is increased over the Tesla system by an additional 500 watts RMS via a Reus designed and installed amplifier. Again, a separate woofer control is optional.
    System 4 - Target price $4,600
    System 4 is similar to System 3, except that dual 10" woofers are employed instead of the 10” and 8” woofers found in System 3. Reus indicated that System 4 is designed for people who listen predominantly to "House Music or Hip Hop". The woofer control in System 4 is standard.
    System 5 (Audiophile System; Still in Development) - Target price $5,200
    Reus contends that System 5 is intended for extreme audiophiles. The availability of System 5 is indicated to be several weeks awaym as they are still working to final a new door speaker design. The Tesla factory woofer is replaced with a new 8" woofer that is coupled with a 10" woofer module. As in the other systems, the factory tweeters are replaced, while the lower door speakers will also be replaced. An additional small front speaker is also added to enhance the front soundstage across the dash. Both electronic and passive crossovers are added, and power is increased (over the Tesla system) by the addition of a Reus designed and installed 500 watts RMS amplifier. The woofer control is standard.
    Reus maintains that their system is fully compatible with Tesla’s design, and that any modifications made by Tesla with respect to equalization, etc., will be automatically detected and compensated for by their system. I am unsure how this is accomplished, and suggest that anyone that is concerned about this point discuss it with Reus Audio.
    I have not heard any of these systems, and thus cannot comment on how they sound; I am simply providing information to others that has been provided to me. I do know that Reus Audio is well regarded and has been around for a long time. I strongly recommend that anyone considering their upgrades contact the company directly to discuss any questions/concerns you may have with them, so you can make an informed decision. It is my understanding that they intend to be in New York in July to do several installations, and will come to the DC area if there is enough interest.
  12. ken830
    San Carlos, CA
    Are these upgrades only available to cars with the Studio Sound option?
  13. swegman
    No, as noted above, slightly different designs are provided for non-Studio Sound vehicles.
  14. ken830
    San Carlos, CA
    Yes, but no mention of the rear hatch speakers?
  15. spatterso911
    I can chime in here, as I have had Reus upgrades in my previous car and now my P85. The rear hatch speakers do not need to be changed, as they are more functional as rear speakers in a 7.1 set up. They are more active when you select the Dolby option, and if sitting in the back seat, you can REALLY hear the difference. The systems described above are developed to be applied to both the standard and Tesla upgraded sound systems. The 8" sub output is very impressive. The front tweeter created a sound stage that sits just beyond the windshield, giving a more concert-like impression. The system responds to all Tesla software EQ inputs and any subsequent updates to their settings will work with the system, so it is very unlikely that you will have to have adjustments made, however, that being said, Reus is very responsive to it's customer base (in my own experience) and will adjust to meet your needs. In answering swegman's query on how they accomplish the EQ integration, their amps do not replace the tesla amp, it receives input from that amp and then applies its own power and crossover adjustments. So, whatever changes are made at the Tesla amp level are applied across the whole audio system. For those that do listen to a wide variety of music genres, I highly recommend adding the bass control knob, as you can tailor your sound completely. We already know that the Tesla receives varied sound sources and thus receives varied sound quality samples (FLAC, MP3, M4a...) so adding the bass control makes good sense.
  16. ken830
    San Carlos, CA
    But Tesla standard sound system has no speakers behind the grill of the rear hatch at all, and no Dolby option.
  17. Jack_L
    Jack_L Member
    Massachusetts
    Is there any way to get Sirius with Reus, or must one pay Tesla the $2500 upgrade fee in addition to the above Reus upgrades?
  18. lloyds
    lloyds Member
    Bay Area
  19. nkohlimd
    nkohlimd Member
    Natick, MA, United States
  20. rammer91
    rammer91 Member
    San Francisco
    Hi! I'm interested in a Reus system and will be ordering my Model S soon. I'm pretty confused as to whether it's better to skip the Tesla high fidelity sound and just start with the standard sound, or to order the high fidelity sound and then Reus builds from there. The configurations and prices above . . . does that assume one starts with standard sound?
