Helpful guy that I am, I pulled my subwoofer apart out of the trunk just so you could see the back of the cabinet....Whew! Now I'll go and re-install it...![]()
Yet Another angle..
It's a down firing driver.Is the sub firing through the carpet in to the remaining trunk well space?
Does Reus run power to the 12v battery in the front? Any issues so far with 12v system?
I had the center channel installed with my Reus system and I am not convinced that it is needed. Even they will say that it is really only used with overly-compressed tracks to give a little high-end boost (it has it's own control). I have tried it a couple of times, but I usually just leave it set to a bare minimum where it gives an almost inaudible fill to the high frequencies. But since I am slowly replacing any older CDs that have too much compression with remastered versions (just got in the Yes '90125' disc - whoa!), it doesn't get much use.I'm not quite convinced that a center tweeter aimed at a curved glass surface has any validity to it, audio wise.
