Jeff Foust of Space News tweeted that F9-024 JCSAT-14 has had 7 full burn static fire test with no refurbishment between burns.
That is good news for reuse of a booster stage.
I wonder how many can be stored in Hawthorne? I think that the hangar in Florida was almost full.
SpaceX puts historic flown rocket on permanent display
From what I've read, they don't think they can (or want to) refurbish the cores they've gotten back more than once or twice, hence the Block 5 work. In that case, I wonder if they'll launch some of the heavier payloads on the returned cores as expendables.
A third rocket was seen arriving in Florida. This is almost certainly the first reused booster for the SES-10 launch in March. This makes three rockets sitting in Florida awaiting a launch from LC-39A. The order is now:
CRS-10 around Feb 14th
EchoStar 23 around the end of the month - with no booster landing.
SES-10 in early March - first reuse flight and likely no booster landing either.
SpaceX tends to give customers with delayed launches better performance (might cut transit time to GEO by 1-2 months). By doing a supersync launch, SpaceX might remove the performance margin for recovery. That's the premise why SES-10 is expected to be a expendable launch. Besides once this works, customers will line up wanting the same. SpaceX really needs to recover upcoming block 5 boosters.Don't you think they will at least try to recover the booster? SES-9 weighed the same as SES-10 and although the landing was unsuccessful, they tried to land on ASDS. Also this booster would be incredible valuable for SpaceX, having gone through two launches and landings.
I do think that if they manage to land the SES-10 booster, they likely won't reuse it, but tear it apart and inspect every inch.
Hawthorne is the main factory. If a booster is there, it is for refurbishment or examination. A used booster was recently seen in the factory and I expect that is the booster that will be the first to be reused. That is for the SES-10 launch out of Florida that is likely to occur late February, early March time frame. It will likely be the third launch from now with EchoStar next, CRS-10 after that, then probably SES-10 with the reuse of the CRS-8 (first ASDS landing) booster.
List of Falcon 9 and Falcon Heavy launches - Wikipedia
There are currently 7 used boosters.
#1 is on display at Hawthorne
#2 will be reused for SES-10
#3 is the hot landing with max damage being thoroughly tested at McGregor. It has been re-fired for full burns at least 8 times. It will never be reused except for testing.
#4 was also a hot and hard landing - no clue where it is. See #5 and #6.
#5 might be used as the side booster for Falcon Heavy
#6 also might be used as the side booster for Falcon Heavy - 2 will be needed
#7 is on the ASDS JRTI coming back to port right now
So we know of three that will be used. It is possible that another will be used for the Commercial Crew uncrewed test flight and another for the in flight abort test.
First of all, thanks for all the info you supply on the SpaceX plans/logistics. Fascinating stuff.
I think this is the second time I've seen the theory of re-using boosters for the FH launch.
Question: Are you suggesting using previously-flown boosters for the initial FH launch?
Given the relative immaturity of the re-use portion of the operation, and the fact that FH is a new beast (admittedly reusing known components, but in a new configuration/operating mode), I would have that that eliminating variables for the maiden flight would have been a goal.
Unless of course the thought is that a proven booster is more reliable than an unproven one... in which case that also makes a great statement to (potential) customers...
Not sure if this has been discussed before, but do we have any idea what they learned from inspecting the landed cores, if they had any challenges refurbishing them or test firing them? Also with Block 5, what does easier to reuse mean?SpaceX did a static test fire of the soon-to-be-reused CRS-8 booster at McGregor before it is taken to Florida for the first launch of a previously used booster. That will be for SES-10 and will happen sometime in March. I don't expect SpaceX to try to recover the booster again since SES-10 is almost as heavy as EchoStar 23 and SpaceX is choosing not to recover that booster. So after CRS-10 there will likely be two launches back to back without an attempt at recovery. SpaceX still has at least two other recovered boosters that can still be reused and probably will sometime this year.
Prepping for Re-Launch: SpaceX Test-Fires Used Falcon 9 Rocket (Photo)
"Easier to reuse" means that they learned something from inspecting and refurbishing the landed cores. But they are pretty secretive about stuff like this, and rightly so. Why give the competition useful hints?Not sure if this has been discussed before, but do we have any idea what they learned from inspecting the landed cores, if they had any challenges refurbishing them or test firing them? Also with Block 5, what does easier to reuse mean?
