I would have thought de-orbiting by power would be excluded due to the high fuel load required ie higher for first AND second stages. I've never heard of plans to recover second stage- sounds amazing. Parachutes sound pretty cool dunno if it's possible, though!Anyone care to speculate how they will attempt recovery of 2nd stage? Vertical landing or via parachutes? Given that it is at orbital speeds during payload release , do they have to let it go around and then do a de-orbit burn?
I find Facebook extremely hard to use. However, there is a short discussion of it on Reddit.There is an extensive discussion on the Facebook SpaceX group about how a second stage could be recovered.
So...is Elon saying that he wants to work toward landing the 2nd stage like the 1st stage? I think so. Fiendishly difficult. 2nd stage makes it to orbit so is traveling very very fast. De-orbiting it through the atmosphere produces a lot of heat and it only has a single engine to use, an engine optimized for vacuum operation, an engine that is not steerable. And of course the 2nd stage would need side thrusters, grid fins, and lots of heat shielding. Making it much heavier.
Are you referring to the F9 2nd stage? Then my apologies, I didn't realize that.the Merlin is Gimbaled to move and there are 4 Draco engines for reaction control
So then it seems at least possible that Elon is thinking about a retropropulsive landing for the 2nd stage. But it would certainly need a lot of modifications (adding mass) to survive re-entry without incurring significant damage. And extra fuel, which adds mass.
Fiendishly difficult, in my completely inexpert opinion.
That's not a significant issue. Adding grid fins and cold gas thrusters is a given and those aren't that heavy. The big deal is thermal shielding and how to land (or get retrieved in the air by a helicopter or jet).Without those fins 2nd stage cannot maneuver in the atmosphere. That will be one of the challenges
My (admittedly limited) understanding is that the difference in a vac Merlin and a atmospheric Merlin is nozzle size. It also is of note that the larger nozzle is in two pieces (the separate extension being the larger pieces, as shown in the pic in the above reference).The fundamental problem with a propulsive landing for S2 is a vacuum nozzle has flow separation problems at sea level, that prevents safe usage for that. For that reason the ITS SpaceShip has 2 sets of engines, a bunch of vacuum engines for normal high altitude/vacuum flight and a set a sea level engines for landing.
There are more differences than the nozzle. But yeah bigger nozzle = higher expansion ratio. That's the sole purpose of the nozzle. Instead of letting the exhaust gas expand into air/vacuum and waste a lot of its thrust, the nozzle acts as a reaction area that converts more of the exhaust into thrust.My (admittedly limited) understanding is that the difference in a vac Merlin and a atmospheric Merlin is nozzle size. It also is of note that the larger nozzle is in two pieces (the separate extension being the larger pieces, as shown in the pic in the above reference).
So in one early case, a nozzle developed some cracks at the end, so they simply cut that section off., although that only represented about 1.3M. So there's some variability in the criticality of that nozzle length. It also appears that extension is not actively cooled.
So... what if they found some way to vary the nozzle size? Or discarded the extension?
While the engine might not be running at optimum during the landing effort, would it be sufficient to do so?
