I thought I’d share my experience with these new tires as I had to prematurely replace my tires on my Model Y with only 26,000KM (16,000 Miles)
Some context: Recenlty I had the misfortune of going over a screw that was right on the wall of the Continentals that come with the car. After visits and opinions from multiple sources, including Tesla, it was obvious that the location of the puncture would not allow for a patch/plug or repair of any sort. It was here that I realized that Tesla roadside will not come out to see you for the repair, unless you agree to a tire replacement in the event the tire is not repairable... I guess as they don’t want to send a tech out only to be sent away leaving the owner without a drivable car. Tesla quoted me $450 CAD plus tax for 1 replacement OEM tire. My tread wear on these tires was already down to about 5-6 32nds. Which, I was also advised, would likely require 2 tire replacements on the same axel due to the uneven wear.
It was at this point that I was looking at about 1000 bucks to get 2 tires replaced, and then deal with uneven tire wear between front and back.
I did a bit of poking around but as it needed a solution I decided to just replace all 4 tires with the Bridgestone Tourenzas. I had slight concerns about the fact that they didn’t have the insulated foam like the OEMs, but the reviews seemed great, and the treadwear rating was quite high at 800... I called up my local tire place and was able to get a set of four out the door for $1220 CAD.
Now, I’m not a spirited driver... I drive a lot on the highways and typically try to game the lowest Wh/KM as I can... So I’m not the guy looking for the performance tire. I also was kinda bummed that my tires after only 26K Km were already at the point that they were... rears were quite more worn (to the eye) than the fronts... so this is mainly why I went with the Bridgestones.
WOW am I ever impressed
I can safely say that even with the lack of foam... these tires are QUIET! Going down the road I can say that the cabin noise has reduced compared to the OE tires. The only time I hear them a bit more is when going over any major compression at high speed... best case is the metal connectors you see on a highway when you are going onto an overpass or anything like that... you get a much more noticeable noise... but only when you go over that type of ‘bum’ (I compare it to the sound of a basketball when you dribble it). But I will take that every so often for the reduction in the consistent road noise the tires make.
As for efficiency, I don’t have a concreate answer yet, but it doesn’t seem to be too far off... I believe they are a bit less effiencent than the OEs but not by much. I haven’t had a nice day without wind or cold temps yet to go out for a long drive to test.
Anyways, figured I’d share my experience with these tires.. I’m happy to answer any questions!
