Rial Luganos 19", Scraping Wheel Well, Only in Reverse
Discussion in 'Model S: Driving Dynamics' started by Austin Locke, Apr 3, 2014.
  1. Austin Locke
    Austin Locke New Member
    Washington, IL
    My New 19" Rial's seem to be scraping my wheel wells when at a certain angle when I drive in reverse.
    I don't hear the noise while I'm driving forward but i assume that's because of the "grain" of the tread on Wheel
    The guys who installed it said it's probably due to the offset on the Rial's being +32mm instead of the Stock 19"s +40mm
    Anyone else having this problem?
    Thoughts on a solution?
    Details:
    19" Rial Lugano's Silver
    85K Model S
  2. mnx
    mnx 2013 P85
    Ancaster, Canada
    What tires are you using?
    I have 2 sets of 19x8.5 wheels with +38 offset. I get rubbing in reverse but only with my set of Michelin 255/45R19 tires...
  3. yobigd20
    yobigd20 Well-Known Member
    Skaneateles, NY
    First, what size tires are you using?
    Second, do you know for sure that it is your tires? Are you sure its not related to the TSB for noises/clicking at slow speeds when turning wheel ?
  4. tomanik
    tomanik Member
    Canada
    With the rials and xice3 tires on my car I get minor rubbing from the front passenger tire whenever I turn to the left, going forwards or reverse, when the wheel between 60 to 80 percent of total left turning, if that makes sense. I looked at this and it appears the rubbing occurs on some vent fins that exists on the forward side of the inside wheel well. Nothing of risk, just a little noisy. Not sure if this is the same thing you are seeing.
  5. anthony
    anthony Member
    New Hampshire
    I don't have the Rial, but I did get a different set of aftermarket 19"s. I had the same problem and the SC took care of it for me.
    The curious part of my situation, was I didn't have an issue until after I took it in for an alignment at the SC, when they brought it back, the rubbing was there.
    I believe they ended up making a slight modification to the wheel well plastic bits after trying over and over again to get the alignment to fix it.
  6. mknox
    mknox Well-Known Member
    Toronto, ON
    I have had my 19" Rials on for about a week, and I also notice a minor rubbing sound when I back out of my driveway and turn the wheel. It's the only time I notice it. I don't seem to get it backing out of parking spaces and such. I have the original Tesla-supplied 19" Goodyears mounted to these rims.
  7. AnOutsider
    AnOutsider S532 # XS27
    Ditto here. I get it when backing out of my parking spot at work (while also turning to position myself for the exit). It's very minor though, so I've never focused on it.
  8. Austin Locke
    Washington, IL
    mnx, to answer your question,
    yes i'm using the stock Michelin 255/45R19 19" tires that came with the MS new. I simply swapped the rims from the stock rim to the Rial's
    It's good to know other people have experienced minor noise grating on their tires too.
    I'll probably just end up ignoring it, or having the service center file down the plastic spot on my wheel wells a tad.
  9. mnx
    mnx 2013 P85
    Ancaster, Canada
    Stock tire size is 245/45R19 FWIW. :)
  10. mknox
    Toronto, ON
    So as I think about this, the question that comes to mind is "why only in reverse?"
    The wheel should be in a fixed position in the wheel wheel. Does it move fore and aft somehow depending on the direction of travel and torque applied to the suspension mechanisms? To me, I would think it should not, but am now wondering...
  11. FlasherZ
    I had it as well. The service center said they noticed it and adjusted caster slightly to accommodate.
  12. kevincwelch
    kevincwelch Active Member
    Chicagoland
    No rubbing with mine...forward or reverse.
  13. Austin Locke
    Washington, IL
    Yes, this was the most puzzling part to me as well, but the third party installer did not seem to be surprised by this, and said it was most likely because the weight of the tire shifting forward and back slightly depending on the direction, i can easily find the "angle" it occurs on , and go forward and it makes no noise.
    I've noticed now it only seems to be the front right wheel
    and yes MNX, my tire is the 245 not 255, oops
  14. RobNJ
    RobNJ New Member
    New Jersey
    Hey - sorry to revive an old thread, but i just run across the same problem when I installed my winter tires this year. They are Rial Lugano with Blizzak LM32. They worked without a squeak last year, but this year I'm getting a horrible running noise. I just spoke to service and apparently, when they did the alignment at my annual service they "corrected' the caster angle back into spec by moving it positive by 0.5 degrees. The manager said that little bit of a change shouldn't have made any difference, but apparently he did. Since the wheels are aftermarket, they won't do anything to accommodate, including not realigning back to what they were. I could take it to an aftermarket shop, but he said a change in alignment would affect the handling. In addition, he recommended against heating and reshaping the louvered fender liners for the sake of air flow. He also mentioned that even on the stock wheels, the snow tires sometimes rub when you're going into reverse with the wheel locked, and said it wasn't that big of a deal.
    Can I ask which service center helped you with the adjustment?
    Basically, I was told to either just deal with it or else make my own modifications at my own peril.
    I'm a little miffed because I bought the snow tires last year when i got the car. I went with the Luganos since the stock Tesla winter wheel set wasn't available.
