I purchased the front lighted T and want it to be on all of the time the car is without adding the toggle switch or remote module. Don't want to deal with the extra hardware. If I wire it to the day time lights it will shut off when I turn on the night lights and vise versa if I wire it to the night time headlights. I was thinking of just wiring in directly to the fuse box using the same method in the instructions of tapping into the current for the glove box but not installing the switch module. Has anyone done this and would it be safe as well as only getting power when the car is on? Thanks
That way it will always be on, as the glovebox circuit is not switched off with the car. The LEDs have a life of about 22,000 hours. Rick
It's safe as long as you use the fuse tap to fuse it separately. As mentioned, it will be on 24/7 which may not be desirable. What I did was power it directly off the 12v accessory outlet (cigarette lighter). I don't have the fuse number handy at the moment but it's in the manual. Tapping that fuse will turn it on the second you open your door and stay on while driving. Then once you get out of the car, it will turn off a few seconds after you close the door. Works well for me.
Thanks for the info. Can you tell what number it is from this diagram. Can't see one only #74 says 12V drive rail. This will be much simpler then the other posts of connecting a diode to both the DRL and head lights. Also thanks Rick for your feedback. Love your products. - - - Updated - - - I think I found it #35. Manual says 12 V power socket. Thanks again.
35 sounds about right. To confirm, pull the fuse and see if there is no longer any power to the socket. Once confirmed you can use that fuse as your power source.
