Ride height uneven
Discussion in 'Model X' started by bionichomer, Feb 17, 2021.
  1. bionichomer
    bionichomer Member
    Atlanta
    Is everyone's car ride height even between left and right side. I'm not sure if this is "within spec", but my passenger rear wheel gap is about 1/2" higher than driver's side. I've checked in numerous places to try to rule out uneven surfaces and it's pretty consistent. I've also checked at different ride heights also. Just trying to get an idea if it's typical to have 1/2" variation between sides.
  2. Camelroel
    Camelroel Member
    Lelystad
    How is it with the front? They should be uneven too.
  3. bionichomer
    bionichomer Member
    Atlanta
    Front is pretty much spot on... but I’ll check again after dinner.
  4. Yinn
    Yinn Active Member
    Behind you
    It's not uncommon but if you're in doubt; take it to the service center and request a "ride height calibration"
  5. jboy210
    jboy210 Supporting Member
    Northern California
    You could try setting the car to high. And then to very low. And then back to your normal setting. Sometimes these get out of sync or stuck.
  6. bionichomer
    bionichomer Member
    Atlanta
    Tried this... unfortunately no luck, thanks though.
    I’ll just setup something with the service center next chance I get.
  7. djillusion
    djillusion Member
    Chicago
    I have a similar issue with the rear of my X being lower than the front.
    I have an appt at the service center today to have this looked at along with the shudder under hard acceleration.
    @Yinn - I’ll ask about the “ride height calibration” too. That’s good info to have.
  8. djillusion
    djillusion Member
    Chicago
    to update my status on this thread with the rear of my X being lower that the front. i had the X over at the service center to remedy this issue along with the shudder.
    to fix the uneven ride height:
    they found left rear air strut was leaking, replaced both rear air struts, found left ride height sensor was bent, replaced sensor and calibrated ride height
    air suspension height sensor ASY RR LH
    air spring module rear LH
    air spring module rear RH
    all fixed now and all of it was covered under warranty with no cost to me.
  9. bionichomer
    bionichomer Member
    Atlanta
    That's great, thanks for the update. I hope I don't need air spring module. I hear it's like +$1k each... (out of warranty)
  10. djillusion
    djillusion Member
    Chicago
    i would not want to own any vehicle with an air suspension without as long of a warranty as possible. in fact im convinced i will be getting an extended warranty via Telsa too when the time approaches.
    no matter what car manufacturer, these air suspension components are all subject to failure sooner or later and always expensive to fix.
  11. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    Mercedes AMG had the reputation for super expensive air spring replacements. For Tesla they are much less expensive plus are readily available used 3rd party from dismantelers.
    The air suspension that Tesla uses is many generations advanced from what Mercedes used to use.
    Do not see that many posts re airbag replacements.
  12. Yinn
    Yinn Active Member
    Behind you
    The same goes for any motorized component. The complexity of the X is a massive mean time between failure example. It's also what makes it really cool. But I expect my Model S without power lift gate, w/o air suspension, w/o sunroof, w/o power doors, to be much more reliable.
