Right scroll wheel functionality broken after recent SW update
Discussion in 'Model S: User Interface' started by rabonin54, Jul 7, 2017.
  1. rabonin54
    rabonin54 New Member
    St. Louis, MO
    I have a 2017 Model S 100D. Two software updates have occurred since I bought it about 2 months ago.
    I should be able to briefly press the right scroll wheel to display a list of options for the right side of the instrument panel display. For example to display the energy graph. After a recent update, this no longer happens. Pressing on the wheel now turns off the climate control or turns it back on. Anyone else seen this behavior? I am a newbie, so I may be missing something obvious.
  2. Philgrover
    Philgrover Member
    Loughborough
    Briefly pressing the scroll wheel will operate whatever you've set it up to control - in your case, the climate control. You need to press and hold the wheel to change the left or right sides of the dash.
  3. rabonin54
    St. Louis, MO
    You are absolutely right and I appreciate the response. I must have been using an obsolete version of the user manual:
    To choose what displays on the right
    side of the instrument panel, press the
    scroll wheel briefly until the available
    options are displayed. Roll the scroll
    wheel to choose Empty, Car Status,
    Clock, Media, Energy or Trips, etc.
    When the option you want is
    highlighted, tap the scroll wheel.
    Note: The option you choose to
    display using the right scroll wheel is
    retained until you manually change it.
    It is also saved in your driver profile.
