Right side visualization very erratic
Discussion in 'Autopilot & Autonomous/FSD' started by fisherman, Jan 1, 2021.
  1. fisherman
    fisherman Member
    SFBay
    I'm a reasonably newish Model Y owner with the FSD upgrade and curious about whether what I'm seeing is normal.
    On-screen visualizations on the right side of the car tend to be very erratic. For example, if I'm stopped at a light in the right lane, the lane marker on the right is constantly gyrating and wiggling.
    If I'm driving on the highway in traffic, cars in the right lane will appear and disappear, generally when they're in front or behind me. They sometimes even go left and right across lanes, appearing to collide with cars in front of me.
    After this happened for a while I ran camera calibration with no change in behavior.
    Any insight? While Autopilot tends to work normally, I've had it turn off with "take control now" twice, one even while stopped at a light. I worry that if it's this erratic that I shouldn't be trusting it with lane changes/etc.
  2. JulienW
    JulienW Active Member
    Atlanta
    Normal and you should have been around for the "dancing cars" about a year ago.
  3. powertoold
    powertoold Active Member
    Try to recalibrate your autopilot cameras in the settings. Otherwise, double check the cameras around the car to make sure they're positioned ok and clear.
    Some of what you're describing is typical of the visualization, unless it's happening all the time.
  4. masterxel
    masterxel Member
    Not really normal. Right lane and left lane should be similar. OP do you see this issue with left lane ever?
