Rim Repair - GTA
Discussion in 'Canada' started by realtycoon, Aug 20, 2018.
  1. realtycoon
    realtycoon Member
    Toronto
    Hi, Well I did the inevitable and got a bit of a scrape on the rim. Any suggestions for a rim repair service in the GTA that can fix the cosmetic damage on a 18" Aero Rim on a Model 3?
    Thanks
  2. Tony_YYZ
    Tony_YYZ Active Member
    Caledon, ON Canada
    How bad is it? There's a touch up paint that you can buy from Canadian Tire that matches the aero rim colour pretty much spot-on.
  3. Struja
    Struja "Fanboy"
    Toronto, Canada
    Two possible suggestions...
    Many of us have had our calipers painted at Spence Tire in Scarborough. He farms out work to another guy who does rim repair and I believe we have at least one member who has used his guy with success.
    The other option is to get your wheels powder coated, if that is an option and they will repair the wheel prior to powder coating. I used a guy call Quy's Coating in Brampton. He was quite good but a bit expensive.
  4. Insilin
    Insilin Member
    Toronto, ON
    You wouldn't happen to have the name of the touch up paint? I also scratched my rim and if theres a cheap option then I'm all in.
  5. Tony_YYZ
    Caledon, ON Canada
  6. realtycoon
    realtycoon Member
    Toronto
  7. enwhy
    enwhy Member
    Toronto
