Rim repair
Discussion in 'Mid-Atlantic' started by Chris, Jun 23, 2014.
  1. Chris
    Chris Member
    Maryland
    My 21" rims are in need of some curb rash repair. Really easy to mess up those rims...
    Can anyone recommend a rim repair place in the DC / I270 corridor area? Thank you.
  2. Merrill
    Merrill Active Member
    Sonoma, California
    Chris, you might want to think about trying to do the repair on your own. There are several on this forum who have done that with some success, they want $250 per wheel in this area. If you are going to get curb rash on a continual basis it can get quite expensive. I used 80 grit sand paper to start, the aluminum is soft so sands fairly easily, then gradually go to finer grit maybe 150. Once you have the majority of the rash smooth use 0000 steel wool to smooth out the rim, then tape off the area and spray with clear acrylic sealer. Depending upon how much effort you put into it most people when standing back will not see the rash, probably not as good as a professional but total cost about $10.
  3. Chris
    Chris Member
    Maryland
    Thanks, Merrill. Have you used any paint before applying the acrylic? If so, did you get it from Tesla? I have the black rims.
  4. Merrill
    Sonoma, California
    No, I have the silver. But with black you would need some color to match, I think Tesla has the touch up paint for both the sliver and gray.
  5. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    Tesla does sell the paint for the grey rims as well. Can pick it up at service center and save shipping but call first to check if in stock.
  6. Merrill
    Sonoma, California
    Yes, they show it on line in the accessories.
  7. dsm363
    Nevada
    If you happen to live near or are going to a service center you can buy it there and not have to pay shipping. Saves a few bucks.
  8. Only Trons
    Only Trons Supporting Member
    Northern Virginia
    Chris;
    I had a small curb rash on one of my 19" wheels. I had my car in recently for annual service at the Rockville SC and I asked them to repair the wheel. They sent it out for repair. It cost me $150 -- it looks brand new.
  9. Merrill
    Sonoma, California
    Going in for service on Thursday I will ask them if they have the touch up in stock.
  10. dsm363
    Nevada
    Great. If you call ahead or email then they can make sure they have it in stock so you only have to go once.
  11. Chris
    Chris Member
    Maryland
    That sounds like a great option. Will save me an extra trip to a tire shop. Thank you all for the great advice!
  12. DFibRL8R
    DFibRL8R Active Member
    Leesburg Virginia
    Anyone have any recommendations for decent rim repair shops in the northern Virginia area? I checked with alloy wheel repair in Chantilly, wanted $175 per wheel which seemed a bit steep so I figured I'd do some more searching. Anybody use the mobile repair businesses? The wheels are off the car so I can easily drop them off.
    I repaired the OEM 19's myself which turned out "ok". Matching, blending the paint/clear coat was the hardest part. Now the 19s are used as my winter rims with winter tires. I want my main rims (20' T-Sportlines) to look better than my DIY paint skills might allow.
