RIP #994
Discussion in 'Roadster 2008-2012' started by NomoC8, Jan 16, 2018.
  1. RebelRoadster
    RebelRoadster Supporting Member
    Osceola, Missouri
    I'm still plotting my strategy on this one and open to suggestions!
  2. X.l.r.8
    X.l.r.8 Supporting Member
    Toronto/Miami
    Either way you probably need to pul the pack. So while it’s out it would take only a little more effort to swap the BMB boards for the bypass ones and see if they take and hold a charge. It would make the car more then viable.
  3. RebelRoadster
    Osceola, Missouri
    @X.l.r.8 you wouldn't happen to know if it's ok to swap PEMs between cars? I was hoping to find out if the PEM is digitally married to the ESS or if they simply communicate freely.
  4. X.l.r.8
    Toronto/Miami
    I’m going to say there’s some designation to the vehicle but @petergrub would know better. I only have one car to play with, you have the other one I wanted lol. I don’t imagine it’s a plug and play swap as the the charger and other electronics are also in the PEM and that’s where the vehicle calibration is. I don’t think it’s big deal for the SC to handshake them if they indeed do because they seem proficient at selling new ones.
  5. GreenLine
    GreenLine Member
    The Villages
    @X.l.r.8 based on your experience, on these Roadsters, which parts have the potential to break that will be hard to get?
  6. X.l.r.8
    Toronto/Miami
    #106 X.l.r.8, Jul 15, 2019
    I have little experience, just a moderate amount of knowledge. The 12v DC converter is expensive and hard to come by. The PEM is close to rebuildable. The battery pack is unknown. If you look after it, it looks after you. The rear suspension (non adjustable) is just inadequate and will blow seals easily. A lot of the time location will be a key factor, my roadster tech is confident if I need a battery he can get one, but I think they along with PEM are unobtainable soon. But if I had to say one part it would be the transmission. They are only made for the roadster, and I think you will be looking at third parts stores for them.
    But the potential for them the break seems unlikely. The parts that ‘break’ are silly things, tension straps for convertible roofs, the UMC, the PEM fan. There’s a pretty good warning system on the car that lets you know if your heading that way. If the PEM over heat warning comes on and you don’t fix it, you are going to be renewing the insulation under the IBGT’s. If it’s throwing codes, time to research and if you get to the lower end of your battery and can’t charge, pull the plug and get it somewhere that can. Discharging the battery is usually user error, normally preventable and rarely repairable. The co-part cars are all left to die, if they pulled the plug most of them would be repairable.
  7. RebelRoadster
    Osceola, Missouri
    There are few cars that can put a smile on your face like a roadster, find a good one with a great battery. Almost all of them have had the PEM replaced, but this does not fix the underlying problem (which is completely fixable). They can be very reliable and a ton of fun. All cars come with headaches of some kind, but roadsters are easier to deal with than a lot of cars I have owned. The motor and transmission almost never die, upgrade the PEM with better insulation, check the PEM fan shroud for cracks (or missing pieces), these are the big ones, and be sure to keep the car plugged in.
  8. GreenLine
    GreenLine Member
    The Villages
    Thank you for that information @X.I.r.8 and @RebelRoadster. Looking forward to enjoying riding my Roadster.
    By the way, I have two error codes on the display. One is "GPS: No data fault" and the other one is "DMC FW: Line UnderVoltage fault". I am in the process of researching what cause these codes and a solution for it. So far, no luck. If you can help me with these codes, I will appreciate it very much.
  9. Roadster
    Roadster JdeMO Powered
    SoCal
    #109 Roadster, Jul 19, 2019
    A Wiki of VDS error codes can be found here. As for your specific codes...
    IDColorText under normal circumstancesDebug text (not normally displayed)Notes / Suggestions
    53
    Orange
    Debug-Only Msg
    GPS: No data fault
    1) Check if the APS is inhibited in the service diagnostic menu under the Controls submenu (petergrub)
    2) Check if the GPS antenna is plugged in at the VMS in the dash above the passenger footwell (petergrub)
    937
    Charge Problem Extension Cord Detected
  10. X.l.r.8
    Toronto/Miami
    I would suspect it’s related to the dead ESS. There needs to be a minimum voltage in the pack for the bms to allow the battery to start charging. Either that or you are plugging in a broken cord. No idea what you are using to get that message. I got it once trying to pull more than 10A from a 120v socket with unknown type breaker, and again at my home with gfci plug and gfci breaker.
    The other is probably again because of the dead ESS and the car thinks the main battery is ‘switched off’. All the codes are powered from the 12v battery so unless you can get the pack charged they may be redundant codes, also you have no idea what the previous people did before you. You could look at the sub menu just in case they turned off the pack to try and save it. You might get lucky.
    It’s easier to search using the ID error codes rather than the text.
  11. GreenLine
    GreenLine Member
    The Villages
    Thank you @Roadster and @X.i.r.8, I will check and do that.
  12. RebelRoadster
    Osceola, Missouri
    A small victory for today, but I managed to get the VMS booted up today with a functioning touch screen on #994 (thanks to other posts on this forum!). I was very excited to see there are only 14 errors to work through (it's kinda nice to have a list!). I'm sure a few errors will go away once the PEM is communicating (currently out of the car). Time to pull the batteries and see where we land (I think I know the answer, it's been too long!).
  13. X.l.r.8
    Toronto/Miami
    I would grab some of nicks bmb boards to measure. Hota do a dual balance charger that you could use 9 channels to see what charges, it’s nice as you can set the voltage to each cell and read what’s going on. Being able to see a start point, an end point and capacity each brick took to get there is a great function. It also charges your phone while you wait and the pro version is AC and DC powered.
    https://www.amazon.ca/HOTA-Balance-Charger-Discharger-Channel/dp/B07Q877ZP5/ref=asc_df_B07Q877ZP5/?tag=googlemobshop-20&linkCode=df0&hvadid=341629855162&hvpos=1o1&hvnetw=g&hvrand=11115406364050933743&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9061009&hvtargid=pla-797906302487&psc=1
    The only think I’m yet to verify if it will fully charge from balance leads only. I read that it does but I’m waiting for one to arrive to confirm
  14. RebelRoadster
    Osceola, Missouri
    #114 RebelRoadster, Jul 29, 2019
    Thanks @X.l.r.8 Greatly appreciated! I sent a message to Nick, hopefully I will hear something. Also, I ordered the charger, it should be here on Wednesday. I might pick your brain on the settings to be sure I get it right...thanks again!
  15. X.l.r.8
    Toronto/Miami
    If Nick doesn’t have any I have a set. Which if your doing one sheet at a time then you probably need just one. CDB6F581-533D-4A4F-9070-88982122B261.jpeg
    The ends are available from digikey/Mauser.
  16. RebelRoadster
    Osceola, Missouri
    I ordered the connector from DigiKey today, I might hit you up for a board if you have one available (I might hear from Nick tonight).
    I would be glad to send you a PayPal for it! Many Thanks @X.l.r.8, greatly appreciated!
  17. X.l.r.8
    Toronto/Miami
    I’m away untill tomorrow so remind me. I had a lot made so there is plenty
  18. NomoC8
    NomoC8 Member
    Chi town
    any updates?
  19. spaceballs
    spaceballs Member
    Sammamish
    Wished this board has fuses on each trace, as there was one sheet that i know of that had shorted sense wires and caused all the fuses on it to pop (on my board). Glad I had them present else could have been more of a serious issue.
  20. ra88it
    ra88it Member
    Southland
    Curious what happened to her. I was outbid in the 11k range. I checked the car at capital one motors and deemed it to be too much.
