My 2016 P90D had just crossed the 100k mark and it developed a creaking at low speeds.
Local SC replaced the lower control arms, and suggested I do the brakes and rotors. I realized pretty quickly after that my efficiency was off, as I was suddenly up 60 to 80 wh/mi over my current average. When I called roadside, they noted that my pack temp was a bit high at 105F but was still "within spec". My tires measured a symmetrical 5/32 all around. This lead me to chasing cooling system issues. I also noticed after it was done that I had some odd suspension noises, and I assumed a new wheel bearing was in order.
Second trip the SC to address the "wheel bearing noise" and the efficiency concerns, and they found a backing plate for the brakes needed some adjustment. Nothing else was deemed wrong, but they recorded my tread at 3/32 after only a few hundred miles of driving. I didn't catch the discrepancy in tread depth, which is my fault.
Still fighting efficiency concerns, I realized the noises were still present. I gave Tesla two chances, so I took it to a local shop that specializes in German cars and also Tesla. By this time, we were two weeks and 800mi out from the first SC visit.
My tires are shot. Based on the paint marks, the local shop doesn't believe an alignment check was ever done. The thrust arm bushings are also worn out and ripped, so those should have been caught/addressed between the two visits. Now, on top of more suspension parts, I will need to purchase new tires.
Here's an "in spec" bushing on the thrust arms.
It should go without saying I'm pretty disappointed. I called the SC and they assure me it was put on the alignment rack and everything was perfectly aligned. I explained that couldn't be the case based on what I'm seeing, and the massive tire wear on my Michelin Pilot Sports, which began this journey at 5/32 and are now showing wear bars in the rear and significant feathering up front. "If you went from 5/32 to wear bars in 800 mi because of the alignment, you wouldn't have been able to drive the car". That was the reply from Tesla.
So, I'm now up to $5k between the SC, local shop to get it right, and new tires.
Just disappointing.
This tire was 5/32 800mi ago...
Just disappointing.
