JRP3
Hyperactive Member
I assume the thin sheet is attached to thicker frame rails so you could potentially weld in a slightly thicker sheet which should take care of any strength lost through welding. Or use adhesive as was previously suggested, or a combo of rivets and adhesive. I don't see how the frame was distorted in such a way that a pack couldn't be removed, and if it can be removed it can be replaced.
