Interesting. Two I agree that there is a bolt hole without a bolt. However, based on the pictures I have here:
Found out what’s causing undercarriage composite to break apart
(page 4 of the above thread posted by
@TEG )
It doesn't look like you are actually missing a bolt. As far as I can tell from your pictures, the place where there is a missing bolt, there is no corresponding hole in the undercarriage composite. There should be a total of 6 bolts on the front edge of the rear composite. To me it looks like you still have them all (please correct if I'm wrong). Perhaps the original design of this undercover had a lot more attachment points (which perhaps it needs?).
So, my feeling (expressed in the other thread) was that this cover couldn't sustain damage if it's properly attached and not hit by something. So, I'm either wrong about that, or something hit your cover and ripped it back somehow. Perhaps if sufficient water gets in the small gap (even on a properly attached cover), it can rip it free?
It's really hard for me to say without knowing exactly what the water circumstances were. Personally, I'm not that worried about it (once I get my two missing bolts added), but I'm also in Southern California and huge puddles are generally more rare.
I guess another possibility is that some covers are more "warped" from the factory and have bigger gaps (between sheet metal and cover) between bolt attachment points than others. I have pictures of mine before any damage, and I don't see any major issues, but maybe there was some issue which made the three reported undercover failures more prone to failure.
If the two others here reporting problems could post pictures of the specific damage if it hasn't already been fixed (
@Kentrock1 ,
@_ACX ) (or confirm it is identical in location to
@dbemis damage location), that would be helpful to see if it's some sort of systematic design issue.
