Tesla will probably drop the price of the X now that the Rivian SUV is being released (similar to the Lucid Air response)
Model X is the Cayenne to Model S's Panamera, a car with a tall body and bigger tires. it's the Cayenne of EV's until they make a cayenne EV.
Rivian's stuff won't be able to compete dynamically IMO, soon as there's a curve anyway. I think they're only talked about in the same sentence because they're both electric and the 3-row SUEV class is currently a class of one, and still will be for another year.
It's 5-6" higher off the ground, with a bigger, taller, less concentrated body, likely 1000lb heavier overall, and with hub motors the unsprung weight at each corner is going to be absurdly large compared to Model X's central-mounted, half-shaft based setup. It's not going to go around a corner anywhere near as well as Model X. It'll be Tahoe vs. Cayenne.
So when you say it doesn't compete with Tesla, you mean on a track? I guess I don't really care how my 7-seat SUV handles on a track so I can't comment, but to each their own. I am more concerned with cargo space, range, interior finishes, and ride comfort than how fast it goes.
Thanks for the note on the hub motors, I could have sworn that was in a press release somewhere.
No I'm talking about how it goes around a corner. How a car handles. You know, handling. I assume you have to go around corners and such every day you drive? Same with braking - unless they have some magic at their disposal that Tesla doesn't, bigger car + bigger battery = bigger number on the scales, probably about 1000lb with teh 135 pack, if the Audi is any guide to what other OEM's are able to achieve with a BEV compared to Tesla. The 180kwh pack will probably be pushing close to what a 3/4 ton Diesel weighs. And then you look at how they carry the weight, particularly the Rivian's ride height, and the X carries its weight quite a bit lower, both in the body, which is just more compact, and critically, in how high off the ground the heaviest component, the battery, sits - even at its lowest suspension setting the Rivian is carrying its weight around the same height as the Very High setting on Model X. That's fine, different missions.
They're not in the same class on that front. One is a tall car, one is a trucklike utility vehicle. Insert your comparison here, Range Rover to X6, yada. That big of a discrepancy in how they carry their weight and how much of it there is means very different characters from behind the wheel. That more "carlike" feel might not matter to you, but it matters to a lot of people, otherwise we'd all still be driving body on frame SUV's
Like I said up above, *I'd probably have a Rivian on order right now* if they had been making cars for more than negative 1 years. I don't particularly need my SUV to go around a corner better than a Rivian can, if it can also tow my car hauler, but X is the only show in town right now and I'll enjoy the dynamic superiority in the mean time, and curse the doors. They're two cars at similar price points and similar power sources, with very different missions.
Rivian looks like it has some winners for sure. Would definitely consider it if I lived in populous areas and didn't need it to go on long road trips. There are still big swaths of the country where there are zero CCS chargers and even bigger swaths where there are some but only 1-4 at each station. That somewhat works now but not in another year or two. Still comes down to the Supercharging network for me.
7 seater Model X is cheaper and more comparable ($81,990). Cost of ownership is potentially higher on the R1S because it will have a higher consumption. Range is better on the X.I just priced out the R1S with the 7 seats and came to $70,000 before the $7,500 fed rebate. Compared to the 6 seater model X that was about $87,500, this seems like a great deal with a total price difference of over $25,000.
Am I missing something? Besides the charging network, what would make someone spend an extra $25k when cross shopping 3 row midsize EV SUVs?
