Road noise!
Beckler
607
550
Canada
Less acoustic insulation might actually be safer as it allows the driver to hear outside horns, bells, etc., better. Sort of like tinted windows; does anyone actually think those are a good idea safety-wise? Although in that case since tinted windows = drug dealer, they're not overly concerned with their safety anyway. :)
  • Disagree
Reactions: TLLMRRJ
Flekoun
102
101
Poland
someone did, don’t you read every single model y post like I do? Lol
Model Y - Hands On
With the performance. Only one data point but it’s a start.
Thanks a lot! For anyone browsing this thread here is a copy&paste, looks good so far. Honestly too good to be true :)
So on my trip today, I measured cabin nose and it seems a lot better than our M3.
55-56db @35mph - asphalt
56-57db @ 75mph - concrete
58db @80mph- concrete
59db @85mph- concrete
Taken on my Pixel 3 XL with 'Sound Meter'. Phone sitting on arm rest of console.
Uncle Paul
6,299
6,879
Canyon Lake,CA
For some manufacturers, an extra quiet interior is part of their design focus. The extra insulation or dual pane side windows add cost, compexity, build time and weight. Lexus used to advertise that their motors ran so smooth you could balance a coin on it while running. If you need a car that can balance a coin while runing then perhaps an earlier Lexus LS 400 might be your choice :)
Trade off is that they will cost more, have worse aerodynamics, handle worse, get worse fuel economy etc.
Tesla cars tend to be pretty quiet due to smooth electric drive, They seem to get even quieter after a few years of production as build quality improves and lots of little adjustments all add up to the cars evolving better and better. Wind noise is not determined by the type of engine, so Tesla will have no edge there.
Some cars can be made quieter by using aerodynamics to bend the wind away from the offending areas. This will make the car quieter, but less aerodynamic.
Stand next to an idling Tesla or ICE and the ICE will sound like a bucket of bolts in comparison. Some of the ICE comparisons also come with smaller and narrower tires and wheels. By running skinny tires the cars can be made quieter as well. (but worse handling).
Tesla has announced that they could make their cars much quieter if allowed to replace side mirrors with cameras. Lots of wind noise is caused by those mirrors sticking out of the smooth body. In addition to less wind noise, it would also allow the vehicle to get better range as that significant aerodynamic drag would be eliminated.
Photos have shown that the mirrors on the new Y stick out much less than those in the Model 3/S/X. This alone might be causing some of the reduction in wind noises.
Reactions: Electric Steve
cucubits
1,716
916
TX
I'd love to see the side mirrors go away. Check out how awesome e-tron and honda E systems are in Europe.
It will be a good while until those will be approved here with the regulators seemingly being hell bent against progress.
I think a lot of Tesla wind noise is also coming from poor panel and glass alignment.
  • Disagree
Reactions: PhilDavid
frankvb
916
558
San Diego, CA
One problem with cameras is that you can't widen your view by moving your head left or right. The camera will just have a fixed viewing angle. Of course could be improved by making the camera more of a wide-angle one.
Chgd Up
Sig 1004
Dec 18, 2012
75
37
United States
I had the opportunity to drive 30 miles in my Model 3 to pickup a new Model Y 10xxx vin, AWD non-performance. When we drove back the same route in the Model Y the Y definitely seemed quieter.
Listening carefully the main sources of noise below 70 mph were road noise coming from the back of the vehicle behind the rear seats. Folding down one side of the rear seat it was possible to localize the largest noise sources to the rear corners of the car where the drafter vents in the back rear are located. These vents allow air to escape from the vehicle but they also on the highway are allowing road noise into the cabin. Some of this might be reduced if there were a cargo cover over this area as on the Model S.
This is a picture of the passenger side vent it is above the rear stowage hole on that side. There is a similar vent on the driver side in the rear behind the charge port area.
