Road Noise
Discussion in 'Model X' started by Hitman007, Sep 27, 2016.
Tags:
  1. Hitman007
    Hitman007 Member
    Florida
    One suggestion I would offer to Tesla is they need to address road noise. For the cost of an X I would expect it to be at least as quiet as a BMW or Mercedes SUV especially since there is no engine noise. But my X is as loud as my wifes Honda Pilot. The solution is simple.. just add more & thicker sound absorbing insulation around the cabin and on the floor. The cost to do that seems negligible. They should use the Lexus LX as the mark to shoot for in cabin noise.
  2. K-MTG
    K-MTG Sunshade Captain of TMC
    Irvine, CA
    The X is as loud as my MDX but so was the S loaner I got while my X was in service so I don't know what quiet is expected to be
  3. Joer293
    Joer293 MODEL X P100DL
    Maryland, United States
    My 2016 X is much quieter than my 2013 S was. By about 15dBa, when I measured it. I would say my X is now as quiet as our Acura MDX. Tesla just isn't in the same category of creature comforts as Mercedes. The road noise now doesn't bother me as much as the low frequency resonations from the suspension over rough highways. Something Mercedes and BMW solved along time ago. Most other owners can't hear it, but I can when in their cars.
  4. K-MTG
    Irvine, CA
    I can hear the suspension air noise when I slow down.
  5. Hitman007
    Hitman007 Member
    Florida
    I might take mine to a car stereo shop and have them put sound guard insulation in the doors and under the carpet. Basically wrap the cabin.
  6. BandE
    BandE Member
    Montclair, NJ
    My 2013 Model S was far quieter than my 2016 Model X, which has been to the shop for multiple (at least 4 times) wind-noise/door/fit/tolerance issues and adjustments. Today, I added about $20 of FrostKing EPDM 1/4" D-shaped rubber weatherstripping from Hope Depot around the 4 doors (skipped trunk). Adhered it to painted surfaces (some on doors, some on chassis) for a tighter fit. DRAMATICALLY REDUCED ROAD NOISE, such as sound of oncoming cars passing, neighborhood dogs barking. We can actually hear the noise of the electric motor again as the car accelerates and drives. Huge improvement with a home-made modification that Tesla just couldn't do on their own.
    • Informative x 3
  7. Hitman007
    Hitman007 Member
    Florida
    Can you post a photo of the door area so I can see what you did?
  8. Martin VanB
    Martin VanB Member
    Canada
    I would like to see that as well. Sounds interesting.
  9. Tjhappel
    Tjhappel Member
    San Clemente, California
    Yeah please show me pics, I too can't stand the wind noise this car generates. I'm getting the smaller wheels so hopefully that helps a ton but I'm sure I'll just notice wind more.
  10. xkwizit
    xkwizit Member
    Folsom, CA, United States
    @Hitman007 - How many decibels are you recording inside your vehicle when driving?
  11. 3s-a-charm
    3s-a-charm Active Member
    Calgary, Canada
    There is a guy on here I remember seeing who took his Model S in for full soundproofing treatment (stripped the car to do it) and had a significant improvement.
  12. mohanman
    mohanman Member
    Michigan
    Yes! Please show us how you did it! The noise is the only thing I don't like about the X! The current soundproofing/weather stripping material looks cheap and whoever at Tesla was responsible for this part of the car, did a bad job.
  13. Dynamo123
    Dynamo123 Member
    DC
    Yes please post your details as to where you put the weather stripping. I had a Model S prior to my X and the road noise difference is night and day. My S was very quiet, but I hear everything outside of my X. I also brought in my X for Service 3 different times and they told me that the road noise level was in acceptable range each time telling me that they adjusted the small triangular window, which has never been an issue that I could hear, and reset the windows. Thanks in advance!
  14. mohanman
    mohanman Member
    Michigan
    This car gives me a headache. I am not sure if its the seat, the Michigan crappy roads, or the rough ride. My wife won't sit in it anymore, especially with autosteer on local roads as it seems to ping pong back and fourth between lane markings. Anyone else get headaches? It may also be the pickup.. maybe doing mild whiplash to my neck, since the seat doesn't seem to have great upper body support.
  15. mohanman
    mohanman Member
    Michigan
    I think BandE is on to something here. I found some left over foam stripping and placed a ring if it around my driver side door.. and I think it made an impact. Could be placebo effect.. but I am going to try all the doors. By the way has anyone ever added extra padding to the driver chair? Its really stiff and hurts my back.. do you think it could soften up with time?
    Thanks
    Mo!
  16. hiroshiy
    hiroshiy Supporting Member
    Tokyo, Japan
    I personally think my former Model S and current Model X is very quiet, but would like to know more objectively. How do we measure noise in dB, with our smartphones? Would that be good indication of noise levels in general, or do we need to use some good audio meter?
  17. Electric Dream
    UK
    The sound level measuring in phones is getting better, but even if you had a professional sound meter you would need to devise a repeatable test to make any useful comparison.
    The orientation of the sound meter, distance from noise source, background noise, frequencies being measured and other variables will all have a bearing on the number you end up with and if you then repeat the test with another car on another day, how can you be sure you've got everything consistent?
    Noise is also quite subjective. Some people don't mind some types of noise but are irritated by others. it's a subject the auto makers take very seriously and spend a lot of time and money getting right.
    If it's road noise you're trying to reduce, you'd probably find more benefit from changing to a different brand/model of tyre than adding sound-deadening materials to the inside of your car.
  18. Pilot4Hire102
    Pilot4Hire102 Member
    Zion Crossroads VA
    I've owned a few luxury vehicles and my wife still drives one . I have come to the conclusion that this is a bit of an illusion - at least In my car.
    Because there is little to no engine noise or transmission noise you " hear " the wind more than you would in an ICE car.
    I think my car has less noise than my best friends brand new BMW - once you take into account it doesn't have a combustion engine to cover up the wind .
    I can say that any car can benefit from dynamat installation to decrease road noise - no matter how good or bad it is. I plan on getting the doors at least done in it.
    • Disagree x 1
  19. Hitman007
    Hitman007 Member
    Florida
    Thats is true about the engine noise absent from a Tesla but to me it seems the harsh noise I am talking about is coming from the road. So it would seem that a dynamat installation under the carpet would really help.
  20. Pilot4Hire102
    Zion Crossroads VA
    I wonder has anyone had experience with different tires than what comes with the car ? Are the ones included maybe rated poor on road noise ? I haven't looked into that at all .
