Road trip advice
Discussion in 'Model S: Battery & Charging' started by FlyingJat, Apr 5, 2015.
  1. FlyingJat
    FlyingJat Member
    Washington - the State
    Leaving on my first road trip in a few hours with my one week old 85D. The destination is Salem Oregon. There are two SuperCharge stations en route. The car is 100% charged and indicates range of 271 miles.
    The navigation says that I need to stop at the first one in Centralia, WA - just 40 miles from leaving home - for 30 minutes. The next is 110 miles down the down the road in Woodburn, where I am told to stop for 15 minutes.
    I don't understand why i would need to stop for 45 minutes at two station when the end destination is only 170 miles.
    Any thoughts?
  2. RichardL
    RichardL Member
    San Carlos, California
    Mainly, it depends on whether you have destination charging available?
    If you do, so are not depending on charging this leg for your return, then I would easily do the journey non-stop - I have often driven the 196 miles to Harris Ranch from my home, staring with a 266 charge.
    Just don't go crazy fast and monitor the likely remaining charge at the destination, if it drops too fast, slow down, and if it keeps dropping below your comfort level, then stop at Woodburn.
  3. FlyingJat
    FlyingJat Member
    No charge at destination - so I was planning to stop at Woodburn. Nice shops for the wife there too. Did not understand the need to stop for 30 minutes just 40 miles into my trip. Thanks for the re-assurance Richard.
  4. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    The new trip planning feature in 6.2 has been observed to do some wonky things. Try this: set your destination to Woodburn and look at the Trip tab of the Energy app. If the predicted state of charge at your destination is not less than 12%-15%, there's no good reason to stop at the intermediate Supercharger. If it's only 150 miles from home, that's a slam dunk under all but the most unfavorable conditions. Starting with a full charge, any leg less than 170 miles or so should be a no-brainer in an 85D. And if you monitor your progress against the prediction, you'll be able to tell if things are going sour long before it's critical. If you're worried, slow down 5-10 miles per hour and reevaluate after 15 minutes. Plan to arrive at the next Supercharger with a reasonably low SOC: you'll charge at a higher rate the closer to empty your battery pack is.
  5. jerry33
    Texas
    It's not a bad idea to check the car's calculation against EVTripPlanner. Neither is 100% accurate because of variables they can't control, but by using both you'll get a pretty good idea of what will work. Having driven a few trips when Superchargers weren't available, I just don't worry about any of the time taken at a Supercharger.
  6. TTT
    TTT Member
    San Diego
    Since this is your first trip, I would go ahead and stop to check out the SC locations. I've found the Trip tab to be pretty accurate as to the state of charge of the battery at the destination, it takes account the terrain. However, it doesn't take into account you testing the exhilaration of ownng a Tesla, if you know what I mean.
  7. Candleflame
    Candleflame Member
    QLD, Australia
    I don't get this. Why not just charge at Woodburn; as the battery will be more depleted it will charge much faster than doing a topup earlier?
  8. brianman
    brianman Burrito Founder
    Apple butter at Country Cousins is pretty good at Centralia.
  9. Candleflame
    Candleflame Member
    QLD, Australia
    are you implying the charger takes the quality of the charge location into account and applies a weighting. I.e. the centralia charger gets a 5x weightning coz of apple butter and hence the navigation suggests to spend 30min there + 15min at woodburn. Rather than ~35min at woodburn only in an empty parking lot?
  10. MSEV
    MSEV Member
    Nebraska
    I can tell you this about my 85D: I traveled from Omaha (Council Bluffs SupC) to KC, MO (Independence SupC) which are about 199 miles apart. I drove too fast for the energy needs going down and hit the mild hills going into KC and made it to the SupC with 10 miles left. I started with 250 rated miles, got about 199 with 10 left. Only adversity was 42F temp (and me driving fast). Going back filled up to about 250 rated miles again (as I recall) and hit a terrible head wind, causing us to need to stop at a J1772 to make it to the Council Bluffs SupC to get enough energy to get home.
    So, in my experience with an 85D, 200 miles between SuperCharges can and will be close if you drive fast at all (70-75), and/or have any weather adversities. So, for me at this point, and I will learn more as I travel more, and see what 6.2 will tell me, but I plan to be careful and have backup places to charge if I have 200 miles between SuperChargers (fortunately, many are spaced closer than this).
    And, IMHO, you won't need to make the first stop if you have time to stop for a longer period for the second one. Just my thoughts.
    Someday, if you do the trip more than once, and try different ways of doing it, I would love to hear about it.
  11. TTT
    TTT Member
    San Diego
    Exactly my point, and I bet if you went 65 you would have ended with more spare mile. Just changing my speed from 75mph to 70mph on a revent trip gave me at leadt 5% more of battery.
  12. cpa
    cpa Active Member
    Central Valley
    And, carry your UMC with its adapters. You just never know . . .
  13. TTT
    TTT Member
    San Diego
  14. Khatsalano
    Khatsalano Member
    San Mateo, CA
    I like stopping at all SCs along my route. They are usually spaced 90-120 minutes apart which is the right timing for me to take a potty break or grab a Starbucks. On every other break (4 hours), I like to grab a meal anyway. I usually stop for 10-15 minutes on the breaks and 45 minutes + for a meal.
    As far as the 6.2 Nav in-car, I can't recommend it at this point. I would highly encourage you to use evtripplanner.com which is incredibly accurate. I use it all the time and have driven 4200 miles in the last month (picked up my S85D on 2/28) with SC use and destination charging. Good luck and enjoy!
    - K
  15. RyanT
    RyanT Member
    Portland
    Another new owner here. On our first road trip we stopped at springfield for a full (90%) charge. Grants Pass SC is 135 miles so I figured no problem, heat on, 10 mph over the whole way. It was raining. Arrived with ~40 miles left, closer then I would have thought. We probably would have only got 170 miles.
    On the way back I was watching the trip estimate as we took a 100 mile detour added onto the 135 miles. We arrived in Springfield with 40 miles left. That charge we would have got over 260 miles. It was at a lower speed, no heater, and no rain. Makes a big difference!
    The elevation change wasn't much 500ft after all the ups and downs.
  16. FlyingJat
    FlyingJat Member
    Many thanks for all the advice. Well - I didn't get to the apple butter in Centralia - but the public toilets are pretty clean. Just enough of a walk to get legs stretched and a bit of juice. Woodburn station also well located. Wife spent the 80 minutes to full charge shopping.
    It is a bit eerie to sit be a chair hooked up to 377V at 220A.
    The percent power predicted was very valuable. En route home knowing Centralia would be waiting to see my red rocket again - I enjoyed the thrill of 110 MPH in near silence as the battery drained down. Survived the trip without running out of power or into the state trooper. :)
    Now the nav system telling me to do a U-turn on the exit ramp - that is another story.
  17. brucet999
    brucet999 Active Member
    Huntington Beach, CA
    Living in SoCal, I don't know much about this stuff you call "rain", so can you explain why rain reduces range? Does D make a difference to range in rain?
  18. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    Increased rolling resistance on wet roads. The same thing happens with ICE cars, but you don't notice when you're getting worse gas mileage like you would when you watch the remaining charge drop!
  19. brucet999
    Do you mean that there is enough energy expended to displace a fraction of an inch of water under the tires to make an appreciable difference? Wow.
  20. snort
    snort Member
    Seattle, WA
    Yep. Think about what's happening: the tire is designed to keep the contact patch as large as possible in the wet and not hydroplane, so it needs to take that thin film and move it all. Various directions, but mostly forwards and sideways off the sides and into the tread. if the road was wet 1/10th of mm and the four tires are all together half a meter wide, 20 meters of road represent a liter of water, all of which needs to be moved (thrown at high speed, really) out of the way. the water is also a little bit sticky (we call it surface tension). .1mm is a well drained, barely wet road. if it's raining hard, 10 or 20 times that is common.
