No problem with this. BUT keep in mind that ABRP is an estimator and no estimator is perfect. So when using it experiment some. What happens if a 20 mph head wind comes up? What happens if it starts to rain? If you are on your way to an anvil collectors show, what's the effect of carrying the samples you are planning to take? More important, when looking at the route, note where you can pick up a supplemental charge if you find that conditions change during a trip.
Most important is to continuously monitor the energy display during the trip. It will, at every step of the way, give you a prediction of destination SoC and show you where your consumption was better or worse than pre trip prediction (the car's - not ABRP's). If the actual line is above the prediction line, Bob's your uncle but if it drops below and stays below with arrival SoC being lower than you are comfortable with, stop and get some charge.
If you know how you can do all this without having to use the display. The consumption shown on the OD's and the battery SoC indicator are sufficient but until you learn your car the energy graph is the best source of info.
