>> Originally Posted by WarpedOne
>> I really do not see why accelerator and brake pedal could not be better used for that.
Zooming through hills, I would prefer to control speed up and down hills just using the accelerator pedal only. If I can pick a heavier regen profile then I can get by on the downhills just by easing up on the one pedal. This makes driving a lot more fun and enjoyable on rolling "switchback" hills which (IMHO) is the forte of the roadster.
Sounds good. Wish I had the $. I like the new specs (no shifting required) better than the old (I don't need > 120MPH).
Wow! This sounds like it should remain as the long term (final) solution. Having a single gear would also allow greater passing response at normal highway speeds.
I see. Then let's join both ideas.
You get a switch (or lever) for setting how much regen (and alas braking) you get from accelerator pedal only.
On the brakepedal you only get an additional potentiometer for sensing its position - more depressed gives you even more regen on the rear wheels.
On the brakepedal you only get an additional potentiometer for sensing its position - more depressed gives you even more regen on the rear wheels. Front/rear braking ratio is set more to the front. I see no big changes in brake subsistem required for that.
I just want to get as much energy back as possible. Don't want to heat the climate.
How much have you driven a vehicle that is designed like this?
I own one in the form of an 06 Lexus. Toyota has invested 100s of millions and many years of development and this vehicle still has the worst braking profile of any vehicle I have owned. It is acceptable for the type of vehicle but nowhere near acceptable for a sports car. The auto magazines would absolutely rip it to shreds over this.
He wasn't asking for actual braking from the accelerator pedal, was he? That wouldn't make sense.
No. Regen goes on the accelerator pedal, braking goes on the brake pedal. There is no reason to mix up these functions and every reason to keep them separate and distinct.
As a driver who revels in the process of revving out a motor and doing a minutely choreographed flurry of arm and leg motion that end in a “slamming” of the accelerator, the loss of that visceral right hand stick motion of pushing, pulling and all around moving those spinning gears to their next position as quickly as possible leaves an empty place in the sports car experience...
Following is Darryl's response from the owners' forum:
Tony - since we are going to a single speed, we have regulatory requirements for PRNDL settings (park, reverse, etc).
TEG said:FYI, my ranger EV (with a single fixed gear ratio) has PRNDE
Where "E" is Economy mode that switches controller profile for
#1: More regen
#2: Reduced top speed
This has been debated upside down and sideways before, but I tend to disagree. I think a blend of regen and friction braking belongs on the brake pedal and a blend of acceleration (positive torque) and deceleration (negative torque) belongs on the accelerator pedal.tonybelding said:It seems to me that regen and conventional braking are two different functions. They are different dynamically and there are different times when you would want to engage them. Regen is a function of the motor and belongs on the motor-control pedal. Braking belongs on the brake pedal.
