...as for the Roadster not losing its acceleration performance after 70mph, I'm fine with that. This car is a true sprinter, that's its specialty, not a car that keeps pulling which eventually can get you into a huge mess. I've had my high speed fun on the street and looking back now it was quite stupid, but that's just a kid testing the waters. Yes I wish that sweet spot went up to 80mph, just for a highway emergency, but I'm not dissatisfied at all. I love the car.
The steering wheel I do enjoy, it has those upper notches for good hand holds while pushing back and forth though the corners. Would be nice to throw something different but I don't want to loose the airbag. I have no complaints, never thought it looked cheap.
As for the battery range and estimate. Note that you take the range mode charge number right as soon as the charge has stopped, don't wait for balancing. You also want to drive the car ASAP, the car is bleeding the harmful high SOC off the pack to prolong its life. I haven't done a range mode charge in 1.5 years, I try to limit those as much as I can. Now when you standard mode charge, don't take the reading or miles as soon as the charge stops, its not a real number. The battery pack needs to balance.... depending how far out of balance it can take longer. For my pack which I keep in balance I allow it to balance / it can take anywhere from 30 mins to over an hour. Then you can take your reading. Good rule of thumb, wait one hour. But allow the car to balance before you go on your journey. Its ok if you miss a couple cycles, it'll catch up next time you balance it. The battery miles even the CAC can differ quite a bit from car to car. Some packs / bricks / cells were stronger, some were weaker. I had an internal fault with my pack @ around 18k or so, Tesla ended up replacing the entire pack for me under goodwill. I was past my factory warranty by 3 months. So they do keep you covered, love the customer service. I then became very good at managing my battery pack. It was a refurbished pack but the CAC reached at one point as high as what the best brand new pack would reach, 160 CAC. That's the highest in health it can go. I did cool-downs any chance I did, kept the SOC down between 50-65% whenever I wasn't driving it (luckily my commute allowed it to land there when I got home), and didn't ask much from the car in terms of power when the SOC was below 50% which can be stressful the lower you go with the cells. I also charge the latest time I could, allowed the pack to balance properly, and did minimal range mode charges. The pack when it did reach 160 CAC only charged to 184 ideal miles in std. mode. Now at 60k on the car or 42k on this battery my CAC is 149.50 and consistently my ideal miles are 180.
But getting back to your pack, try balancing it. Can take a week, can take a month.... Also I don't know if you did this, dump your logs and view what the CAC is. There's some good tools forum members have contributed over time here which are very very helpful, such as the VMSparser and other tools.
