petergrub
I believe you may be on to the issue here. The shifter buttons light up red usually when the PEM is not communicating on the CAN bus. That may be due to a missing connection to the CAN bus, or the PEM is simply not receiving power. When the PEM is not receiving power, then the TCM will also show up as not communicating.Maybe unrelated but when I was having problems all my gearshift buttons also illuminated.
@driver_EV, can you confirm the second error message after the SHFT: Warning Lost Comms DMC? Also, have you pulled the PEM APS plug, RHC33, to check if the terminals are moving freely? Those terminals have recessed on me in the past when you insert the connector and caused issues.
