The diagnostic connector you posted a picture of will be the DC Converter 12v. If you raise the front bonnet then near the wind screen on the passenger side you will see this fuse. Not sure if placement is reversed on right hand drive cars.
Pull the fuse and measure the voltage from each side in the holder to ground (use the AC bracket). One side is the APS voltage from the switchpack. The other is your aux battery. Easier to measure here than under the dash, unless you’re into that sort of thing.
you should really keep all the posts related to your issue in the thread you started about it. Jumping around like this makes it hard to follow where we are and for others to follow if they care to.
