Roadster 2.x TPMS Tool
Discussion in 'Roadster: Technical' started by markwj, Apr 13, 2020.
Tags:
  1. markwj
    markwj Moderator, Asia Pacific
    Hong Kong
    Just a summary of the current metrics (as previously read from can bus) and tyre sets (as manually defined, or previously read and stored using 'tpms read').
  2. pd_australia
    pd_australia Member
    Sydney
    Excited as the TPMS board arrived today. Installation went smooth, left SW1 on 2 and moved S1 to other side of "On".
    Then logged in to OVMS while the car ignition was switched on, and executed some commands (see below) but writing/reading seem to not work.
    How can I check whether the right sensors are installed on the car? or anything else I can try?
    OVMS# module summary
    OVMS MODULE SUMMARY
    Module
    Version: 3.2.014/ota_1/main (build idf v3.3.2-881-g22d636b Aug 4 2020 16:26:20)
    Hardware: OVMS WIFI BLE BT cores=2 rev=ESP32/1
    12v: 13.1v
    SIMCOM Modem Status
    Network Registration: NotRegistered
    Provider:
    Signal: -77 dBm
    State: PoweredOn
    Ticker: 15
    User Data: 0
    HW FIFO overflows: 0
    Buffer overflows: 0
    State Timeout Goto: PoweringOn (in 15 seconds)
    Mux
    Status: down
    Open Channels: 0
    Framing Errors: 0
    Last RX frame: 0 sec(s) ago
    RX frames: 0
    TX frames: 0
    PPP: Not connected
    GPS: Not connected
    Status: disabled
    Time: disabled
    Configuration
    [auto]
    dbc: no
    egpio: no
    ext12v: no
    init: yes
    modem: yes
    obd2ecu:
    scripting: yes
    server.v2: yes
    server.v3: no
    vehicle.type: TR
    wifi.mode: apclient
    wifi.ssid.ap: TSLAOVMS
    wifi.ssid.client: SOTR
    [can]
    [dbc]
    [egpio]
    monitor.ports:
    [http.plugin]
    PINcrack.auth: Cookie
    PINcrack.enable: yes
    PINcrack.label: PIN Crack
    PINcrack.menu: Tools
    PINcrack.page: /store/usr/pincrack
    retools.auth: Cookie
    retools.enable: yes
    retools.label: RE Toolkit
    retools.menu: Tools
    retools.page: /usr/retools
    [http.server]
    [locations]
    Home: -33.791340,151.126648,50
    [log]
    file.enable: yes
    file.path: /sd/log
    level: info
    [modem]
    apn: hologram
    apn.password:
    apn.user:
    enable.gps: no
    enable.gpstime: no
    enable.net: yes
    enable.sms: yes
    pincode:
    [module]
    cfgversion: 2020053100
    init: done
    [network]
    dns:
    [notify]
    [obd2ecu]
    [obd2ecu.map]
    [ota]
    http.mru: api.openvehicles.com/firmware/ota/v3.1/main/ovms3.bin
    server: api.openvehicles.com/firmware/ota
    [password]
    module: **redacted**
    pin: **redacted**
    server.v2: **redacted**
    server.v3: **redacted**
    [power]
    12v_shutdown_delay: 30
    enabled: yes
    modemoff_delay: 96
    wifioff_delay: 24
    [pushover]
    [sdcard]
    maxfreq.khz: 20000
    [server.v2]
    tls: yes
    [server.v3]
    port:
    server: io.adafruit.com
    tls: yes
    topic.prefix:
    updatetime.connected:
    updatetime.idle:
    user: pdanhieux
    [ssh.info]
    fingerprint: i8rI16FOYs+bI37EIJYdgewP18N77uEk5gF9KRTipRA
    [ssh.keys]
    [ssh.server]
    key: **redacted**
    [system.adc]
    factor12v: 195.7
    [tpms]
    1:
    tires: 11111111,22222222,33333333,44444444
    [usr]
    [vehicle]
    12v.alert:
    12v.ref:
    name:
    timezone: AEST-10AEDT,M10.1.0,M4.1.0/3
    timezone_region: Australia/Sydney
    units.distance: K
    [wifi.ap]
    TSLAOVMS: **redacted**
    [wifi.ssid]
    SOTR: **redacted**
    [xtr]
    digital.speedo: yes
    digital.speedo.reps: 3
    REPORT ENDS
    OVMS# tpms status
    TPMS data is stale. Information shown below is not up to date
    TPMS status:
    FL:
    FR:
    RL:
    RR:
    Tyre Sets:
    1:
    OVMS# tpms write
    Usage: tpms write <set>
    OVMS# tpms write tires
    Error: Tyre IDs could not be written to the vehicle (or not implemented)
    OVMS# tpms status
    TPMS status:
    FL:
    FR:
    RL:
    RR:
    Tyre Sets:
    1:
    OVMS# tpms read
    Error: TPMS IDs could not be read from the vehicle (or not implemented)
    OVMS# tpms list
    Tyre Sets:
    1:
    OVMS#
  3. pd_australia
    pd_australia Member
    Sydney
    and looking in the debug shell console, I saw this:
    E (59670) v-teslaroadster: TPMS write (38 bytes) was not formatted as expected
    I (60120) simcom: State: Enter NetMode state
    I (60120) gsm-ppp: Initialising...
    I (62970) gsm-ppp: StatusCallBack: None
    I (62980) gsm-ppp: status_cb: Connected
    I (62980) gsm-ppp: our_ipaddr = 10.117.XXX.XXX
    I (62980) gsm-ppp: his_ipaddr = 10.64.64.64
    I (62980) gsm-ppp: netmask = 255.255.255.255
    I (62980) gsm-ppp: DNS#0 = 212.9.0.135
    I (62980) gsm-ppp: DNS#1 = 212.9.0.136
    I (62980) gsm-ppp: our6_ipaddr = ::
    I (63020) netmanager: Set DNS#1 0.0.0.0
    I (63020) netmanager: Set DNS#2 0.0.0.0
    I (63020) netmanager: MODEM up (with WIFI client up): staying with WIFI client priority
    E (76960) v-teslaroadster: TPMS read was 19 bytes (38 expected)
  4. KJA2001
    KJA2001 Member
    UK
    Do you definitely have TPMS installed? Yours is a UK spec car from 2011 and although these have TPMS transmitters in the wheels they (mostly or always) came without the antennae and TPMS is therefore not functional.
  5. pd_australia
    pd_australia Member
    Sydney
    That's what I suspect as well. Is there any easy way to check without going under the car and taking the bottom off?
  6. KJA2001
    KJA2001 Member
    UK
    If you go to TPMS settings in the engineers menus it will show a blank
  7. KJA2001
    KJA2001 Member
    UK
  8. thefortunes
    thefortunes Active Member
    Wisconsin
    Anybody have a link to the correct TPMS to buy for a 2.5?
    Mine in the summer tires are dead (confirmed by Discount Tire), and my winter tires never had any.
    Looking forward to having this feature again.
  9. pd_australia
    pd_australia Member
    Sydney
    Thanks. Looks exactly the same unfortunately. Guess no TPMS for me.
  10. JohnGarziglia
    Reston, Virginia
    #90 JohnGarziglia, Dec 13, 2020
    I just swapped out my summer wheels for my winter wheels today. For the first time in almost 10 years, I was also able to write the "winter" tire TPMS ID numbers to the TPMS module, rather than chasing down someone at my Tesla SC and hoping they would find time, and find the tool, to do this.
    Thank you again to Mark, Steve and all of the others in this forum who worked on this great project.
    With OVMS programming being continually updated, I hope I am not out of line to make a suggestion as to what the TPMS command info line returns, if possible. It took me a little while going through this thread to recall (or learn again) that I needed the ignition on to "read" and "write" to the TPMS module. This may be self-evident to those who work on the car every day, but it was not something I kept in my mind. Therefore, if the basic TPMS command usage notation could return (with the suggested addition in red):
    OVMS# tpms
    Subcommand required
    Usage: tpms delete|list|read|set|status|write [Note: Turn ignition on to "read" or "write"]
    This is just a suggestion if it fits in with future updates and does not involve a lot of work. I know that come March and summer tires, I will likely once again forget that the ignition must be on to read or write, and there may be others out there like me. Having the TPMS command remind on this would be useful.
    -- John
    [Edit]: Actually, I misspeak. This is the second time -- last Spring prior to the OVMS TPMS function being completed, Steve lent me his ingenious TMPS sensor writing tool which I used to set my Roadster for the summer wheels.
  11. markwj
    Hong Kong
    Glad to hear it is working for you, and a useful capability. It was fun to work on this.
    Regarding your suggestion, it is not trivial to add that text there - as it is auto-generated from the console command line handler and not something we usually customise.
    We can, however, check if the car is on/off and if the tpms read/write commands fail then give a better error message if the car is OFF. I've raised the enhancement request here, to make sure it is not lost:
    TPMS read/write requires vehicle to be ON · Issue #489 · openvehicles/Open-Vehicle-Monitoring-System-3
    Regards, Mark.
  12. JohnGarziglia
    Reston, Virginia
    Yes! An error message there would be ideal. Thanks!
