Roadster 3.0
Discussion in 'Roadster 2008-2012' started by DrComputer, Dec 26, 2014.
Tags:
  1. AEdennis
    AEdennis Active Member
    177 is not bad at all... that’s 220ish range charged.
  2. Bill_Baron
    Bill_Baron Member
    Milford, MA
    Definitely, 177 is a great number for a car of this age. Mine's down to 163, but it's a 2008.
    The psychology of being a Roadster owner is something you'll grapple with. Unlike cars with engines, Roadsters degrade the more you drive them, and you'll find yourself weighing whether or not a particular trip is work the degradation that will take place, fractional as it is. Knowing that after a hundred trips of a hundred miles each, you'll probably lose 5-7 miles of range tempers some of the fun you had on those trips. I admire the folks who don't let it bother them because it bothers me.
  3. shrink
    shrink Supporting Member
    Phoenix, AZ
    177? That's fantastic at this age. Nice choice of cars. Enjoy!
  4. CAR3NUT
    CAR3NUT Supporting Member
    Tucson, AZ
    It is pretty amazing because this Roadster was not a Garage Queen, it has 49,750 miles on the Odometer.......
  5. shrink
    Phoenix, AZ
    Did the car live in a cooler climate before you bought it? Again, that's very impressive.
  6. CAR3NUT
    Tucson, AZ
    It was a one owner car that lived it's whole life in San Diego, which is a whole cooler than where you and I live.
  7. thefortunes
    thefortunes Active Member
    Wisconsin
    Is that on a 120v or 240v charge?
    To get that type of range with that type of mileage it may have had a battery replacement.
    Congrats!
  8. im4uttx
    im4uttx Supporting Member
    Spicewood, TX
    Although that may be the case, I have a replacement battery with only 2450 miles when I took ownership mid-last year. Now at ~186 ideal, but i found the worst loss was when it was left off the charger for ~6 weeks at a repair facility (they charged it once during that time)...lost 2 miles ideal.
    I've put ~2500 miles on it in the last 6 months with no perceptible loss other than the time not plugged in...
  9. AtAge19
    AtAge19 Member
    Cambridge, MA
    Yikes! Another inconvenient reality. Due to such regards, I end up with numerous re-confirming thoughts before finally driving the Roadster around-the-block. No worries, all is worth the efforts!
    - P.
  10. gregd
    gregd Active Member
    CM98
    I'm not sure you lose quite so much in range with use. I've had my car for 5 years now, and in that time I've lost all of 14 miles of range, while putting on some 26k miles (now a bit over 52k total). I retired about half way through that time, and as a result my annual mileage dropped from around 10k to under 4k, but I've not seen a huge change in the rate of decline. This is with the original ESS, which is kept plugged in 24 amps / 240 volts on standard charging.
    The 3.0 CAC analysis thread also shows that time is perhaps a more significant determiner of CAC drop than mileage, at least initially. We don't have a long enough history with it to know how things will play out during the next decade.
  11. Bill_Baron
    Bill_Baron Member
    Milford, MA
    Actually that works out to be exactly the range loss rate I pulled out of my ass. If you were losing 5 miles in range per 10,000 miles driven, I would have expected you to lose 13 miles of range in the 26,000 miles you drove.
  12. gregd
    gregd Active Member
    CM98
    But the point is that it's more related to age than driven mileage, so one shouldn't be afraid to take the car out whenever one feels like it. Taking care of the battery means keeping it properly warm, and staying between 20% and 80% charge. It does not include putting the car up on blocks, or treating it like driving it is doing permanent damage.
    Our cars are incredible, as well as historic machines. They need to be driven and enjoyed, both for our own purposes, and so that others can see them.
  13. CAR3NUT
    Tucson, AZ
    Using the mobile 240V connector which came with the car.
  14. Gremlin
    Gremlin Member
    Washington, DC
    I sent Tesla an email to the [email protected] asking those very questions on 12/13 still pending an answer. Basically I told them I'm on the market for a 2.5 model but wasn't going to buy the car unless the 3.0 feature returned.
  15. wycolo
    wycolo Active Member
    WA & WY
    I can hear the scramble alarm sounding.
    • Funny x 3
  16. drewski
    drewski Supporting Member
    SF Bay Area
    I thought I heard engineers yawning and shaking their heads . . . :eek:
  17. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    What? I am not sure the Roadster degrades much with use. I have 55,000 miles and not sure I can point to a mileage related issue. Like many cars I think the Roadster wants to be on the road. Like me I get stiff if I sit too long.
  18. dhrivnak
    NE Tennessee
    Fortunately the range loss seems to have dropped off. I lost 17 miles in the first year, 7 miles the second year, and it appears I am on track to lose about 4 in this third year. Hopefully this trend will continue.
    • Informative x 2
  19. wycolo
    WA & WY
    So quite possibly the 3.0 battery qualifies as a technically legitimate replacement for the old tech battery, that it might have been discontinued for completely different reasons.
  20. Gremlin
    Gremlin Member
    Washington, DC
    Tyco SC not supporting your Roadster Sethr? I ask cause I was thinking of pulling the trigger on this pristine R80 Roadster but after reading all the 3.0 degradation issues, thinking I'll pass. I'll wait for the 3.0 reboot but that maybe a no go too if Tyco SC can't support the roadster. Rather not ship it across to have Carl fix it. Know he can fix it but shipping car 3000 miles to get fixed is crazy.
