ecarfan
Yes that was posted recently in another thread. But note the VDS shows the battery is at about 80% state of charge but only showing 239 miles of Ideal Range. Less that I am expecting for the 3.0 battery.
Actually Perf mode shows the range as if you charged in Range mode without the bottom 10%. If we assume 10% of the 3.0 battery is about 35 miles and the display is at 80% then a full range charge would be about 345 miles. Sounds consistent with other reports.What looks odd about the mileage/range? To me it looks to be right on for what they promised. Performance mode shows the range as if you charged it in Standard mode. Its about 80% charged in perf mode and showing 239 ideal miles. If fully charged in std/perf mode it would be 300 ideal miles. (each bar notch on the bottom is approx 30 miles). Then you calculate what range mode would be, which is typically 29% more than standard, and it comes out to be 370+ ideal miles (actual calculation is 387).
Update: our new battery was installed yesterday, they kept it overnight to make sure it charges "to the full 330 miles". I expect to pick it up later today.
Cool! Feel free to bring it up to OC! We're having Brunch at Bru (Lake Forest) on April 24, 9:30 AM.Update: our new battery was installed yesterday, they kept it overnight to make sure it charges "to the full 330 miles". I expect to pick it up later today.
I'll probably do that!Cool! Feel free to bring it up to OC! We're having Brunch at Bru (Lake Forest) on April 24, 9:30 AM.
New charge cable? What is new / different ?
+1. Why is a new charging cable needed?
Uh...say again? The 3.0 battery requires a different charge cable, meaning that the charge port hardware is changed when the 3.0 battery is installed?New update: the new charge cable that's needed doesn't work. They're overnighting one, then they'll need to charge it. Sigh.
