Is the charge cable INTERNAL to the Roadster, or is it a new charge port?Small update: new charge cable is in, works, car charging at 40 amps (NEMA 14-50). Maybe get it back tomorrow.
Misunderstanding inside the service center. They hardly do any work on Roadsters any more, so they had no way to charge it! (It didn't occur to me to take my 14-50 cable to them, and didn't occur to them to ask me.) So they ordered a Roadster charging cable. But they didn't give it to me, and there was nothing special about it. Now they have one@ggr, what do you mean exactly by "new charge cable"? Thanks.
I have the Roadster back, 10 days after dropping it off. There's mostly good news, I guess.
It seems to work. Subjectively, in performance mode, it feels just a touch faster than it used to be, but I think it's wishful thinking; the G meter peaked at .66G which is about the same as I remember, so I don't think there's any upgrade to performance.
Now the not-so-good news. They wanted to charge me $29k for the battery, another four hundred for a "PCBA", and over $1000 for labor. I complained about that, because I thought the $29k should be all inclusive for the upgrade. We're still negotiating that.
Misunderstanding inside the service center. They hardly do any work on Roadsters any more, so they had no way to charge it! (It didn't occur to me to take my 14-50 cable to them, and didn't occur to them to ask me.) So they ordered a Roadster charging cable. But they didn't give it to me, and there was nothing special about it. Now they have one.
Then I wanted to check out that the CANs still worked. I began with a silly dance, because it's been a long time since I charged the Roadster in Range mode. So I forgot that every time I'd open the charge port door, it reset to standard mode. When plugged in, all it would tell me was "done charging"... because it was already past the standard mode charging point. There is a solar company in the same complex as the service center, with a "free" J1772, so I took the green machine over there to try it out. I rang their doorbell to ask permission, but no-one answered, so I figured they wouldn't mind too much. Plugged in with CAN jr, but nothing happened. Then a bunch of them came out, I explained about the new battery and what I was trying to do, and they said that the charger had to be activated by a bluetooth app. I downloaded the app, but none of us could make it work; the app didn't believe that this charger existed. Anyway, spent half an hour on that futile effort. Later, after I left, I went past a blink charger on Mission Bay, and the CAN jr worked fine.
CAN Sr, not so much. When I finally remembered that I had to open the charge port door, THEN set range mode, THEN plug in the CAN and Model-S HPWC, it would try to start charging but then complain about loss of synchronization momentarily (didn't get a photo of this), then the ring would go red and another error message. I took a photo of this but for some reason lost it. Henry, @hcsharp, are you there? Is there anything special I needed to do with the CAN Sr in terms of sequence? The only time I've actually used it was a year or so ago, at the exact same HPWC at the service center, just to prove that it worked (and at the time it did). Is there someone at Tesla I should contact about this?
So I came home (via blink above) and tried using the CAN Sr with the Model S' 14-50 charge cable, and got exactly the same result as with the HPWC.
But I can charge it with the original Roadster big-box charge cable, but only at 30 amps (as before). It has the longer range, but unless I can use it with destination chargers, it isn't nearly as useful as I thought it would be.
I'm happy to try things out and answer questions, but if you want the CAC values or anything like that someone'll have to give me a tutorial about how to get them.
I have the Roadster back...
It's seriously stretching the definition of Bay Area to LA.
Why didn't they just use your CAN SR? That's what a lot of people are doing.Misunderstanding inside the service center. They hardly do any work on Roadsters any more, so they had no way to charge it! (It didn't occur to me to take my 14-50 cable to them, and didn't occur to them to ask me.) So they ordered a Roadster charging cable. But they didn't give it to me, and there was nothing special about it. Now they have one.
The CAN SR was tested on a 2.5 that was upgraded to a 3.0 at multiple HPWC locations. I never got a detailed report except to say it worked and "performed as expected".CAN Sr, not so much. When I finally remembered that I had to open the charge port door, THEN set range mode, THEN plug in the CAN and Model-S HPWC, it would try to start charging but then complain about loss of synchronization momentarily (didn't get a photo of this), then the ring would go red and another error message. I took a photo of this but for some reason lost it. Henry, @hcsharp, are you there? Is there anything special I needed to do with the CAN Sr in terms of sequence? The only time I've actually used it was a year or so ago, at the exact same HPWC at the service center, just to prove that it worked (and at the time it did). Is there someone at Tesla I should contact about this?
Just add the "ish" after Bay Area and LA and it works.
For our first test outing, we evaluated the prototype package on a historic route down the I-5 from our first Tesla store in San Jose to the Santa Monica Pier (via the Tesla Store on the 3rd Street Promenade), a distance of approximately 340 miles.
The trip was smooth, with no disruptions. On the highway, we set cruise control to stay right around the speed limit. We turned on the heater for a 40-minute stretch going over the Grapevine. And less than six hours from leaving San Jose, we pulled into the Santa Monica Pier, with 20 miles remaining in the battery pack.
They didn't know it was in the trunk, and no-one I spoke to even knew they existed.Why didn't they just use your CAN SR? That's what a lot of people are doing.
Appreciate it.The CAN SR was tested on a 2.5 that was upgraded to a 3.0 at multiple HPWC locations. I never got a detailed report except to say it worked and "performed as expected".
I'll make some inquiries. Don't hold your breath.
This morning I got a new invoice that reflects this, so they are honoring it.When I enquired about the price increase told to me this year vs the email from last year, I was told that was to cover installation and shipping costs. When I pointed out these were included in the original quote, they said that they would honour the original quote. Sounds like the same thing is being tried here.
Keep in mind that Tesla's blog post about driving a prototype 3.0 Roadster from San Jose to Santa Monica said, quote:It's seriously stretching the definition of Bay Area to LA.
We need to work out if the 3.0 calculates ideal range in the same way or if it has been brought into line with the newer EPA method.
Is it me or is it a little crazy that this costs $29,000 especially when Tesla just received 400,000 reservations for the Model III starting at $35,000?
