@tvuolo: I'm mostly just curious, and not expecting the vehicle's handling to be affected in any significant way.
Every pound matters and degrades your braking, handling, and of course acceleration performance. I'm getting my Roadster aligned again this morning (bumps in the road knocked it off its numbers, love lifetime alignments) and I'm going to 'ballast' the Roadster driver's seat this time. The shop didn't have weights so I had to bring them home from work.... When you drive a car you know in and out by feel and is driven majority by yourself, then add weight in the car, you DO know and feel the difference and it significantly affects handling and braking and acceleration. I tossed in 170lbs in the car yesterday and the car totally handled differently (you feel the extra weight moving around, inertia, mass, etc) and you can feel the brakes working harder. If I don't ballast the car with my weight while on the alignment rack, the passenger rear tire goes more negative in camber compared to the driver's and the front gets wacked too. Meaning, weight changes the way the car's wheels sit on the ground.
If I put down $29k for a battery, I sure as heck would want to know the weight difference between the old an new pack so I could make any adjustments needed with the suspension/alignment.
With weight in mind, if you're an aggressive/performance type of driver in the Roadster and drive the car as a sole commuter make sure you keep an extra safety cushion in front of you between cars when driving and be aware that when someone is in the car, more weight, its not the same car anymore. Many people don't get this nor understand the integral fundamentals of how the suspension / braking components work and changed by every pound of weight.
