ElectricLove
- May 28, 2013
- 551
- 312
Maybe I'm missing something but why are you saying Tesla "did that with the first ones"? They only charge the Roadster (existing cells) up to about 4.15v in range mode and discharge to something like 3.50v. That is not 100% of full capacity, although I don't think they can get any more from the bottom. Tesla rated the whole ESS at 56kWh and 53kWh usable.
Couple things,
1. 4.15V is a pretty high top point, there isn't much left in reserves for the battery at that point, maybe a few % capacity.
2. Like you said, not much left in bottom end either (best to stop them at 3.6V) and this is compounded by voltage sag during discharge because the voltages will dip below this threshold a few times in a cycle.
3. 56kwh rating is the rating of the cells, the cells are rated based on some "ideal" discharge profile, usually this is something like 0.2C for Lithium so that would be 28A continuous discharge (around 10kw), this rating would only be realized in practice if you drove at about 50 mph for 5 straight hours on a dyno, in real use it will most certainly have many peaks which exceed 0.2C and an average which also exceeds that value... What this means is that when the battery allows 53kwh out during a driving cycle it is "basically" allowing very close to 100% of the actual battery capacity (rated for that driving cycle)...
This obviously represents a major challenge for any/all EV manufacturers and the question becomes how to fix it... the simplest answer is larger buffers... the Roadster should have only been allowed 40kwh of its capacity... but then it would have been a 180 miles range car and not beat the magic 200 mark... and there isn't room for more batteries, unfortunately, so at the time the best was done with what was available...
The Model S is also subject to this challenge because Tesla is selling themselves on longer range, of course a 100kwh battery may actually perform closer to 100kwh because 0.2C would mean 20kw of power (appx 60 mph speed)...
I just think for long term durability it makes more sense to have 20% less range but a phenomenal longevity due to gentlest possible battery cycling. Chevy has done this in the Volt, will carry it through to Bolt, Toyota has done it in Prius (who else has several million cars with electric motors and battery packs on the road... no one)... not saying the Tesla isn't a better car, it is, but those engineering risks are errors made in young companies which we alpha/beta owners bear the burden for...
