Roadster 3.0
DaveD
EVs Kick Gas!
Aug 18, 2007
642
242
Redmond, WA
By the way, I did a Range Mode charge as part of my successful trip from my home, driving around Mt. Rainier (stopping at Paradise), and then back home, without recharging. A trip of 232 miles.I had a reported 106 Ideal Miles remaining.
I forgot to add that at the start, it reported a range of 346 Ideal Miles.
Reactions: dhrivnak
DaveD
EVs Kick Gas!
Aug 18, 2007
642
242
Redmond, WA
You aren't a very trusting soul, are you? :D
Right before I started the trip, at home:
At Paradise:
Back Home, Range:
Back Home, Trip:
ecarfan
19,186
13,841
San Mateo, CA
Yesterday I did a Range Mode charge of my 3.0 battery, The first since it was range mode charged at the Service Center the day I picked it up. Curious, I checked the SOC diagnostic display...I noticed the "kWhR" value of 78.63kWh.
Thanks Dave, very interesting!
Does anyone know if the "kWhR" figure of 78.63 shown on the VDS screen in Dave's post is the usable figure or the absolute total capacity of the battery? Given the "R80" badge, I assume the latter.
DaveD
EVs Kick Gas!
Aug 18, 2007
642
242
Redmond, WA
I believe that it's simply an algorithmic attempt to quantify the energy currently stored in the battery.
I just took these pictures below. I've been out on errands this morning since my Roadster had Std Mode charged earlier, at 2:00am.
Range:
SOC:
The fact that it showed a 78.63kWh value after a Range Mode charge is, I think, a good confirmation of the validity of the "R80" badging, but that's all I'm taking away from it.
Marius
215
304
Berkel en Rodenrijs NL
We see significantly improvement in 0-60 miles time for the model S with battery upgrades of just a 11%
Did anybody already experienced the same when getting the R80 battery for the roadster? I can imagine that voltage drops less when making a 0-60 Sprint with the new pack and more then compensating the additional weight results in decreasing the dragstrip time?
wiztecy
2,905
563
I know for sure that you're 0-60 times will be more consistent and hold longer now that the ESS is larger for the reason it takes longer for the voltage to drop. I'd also presume we'd get a slight improvement in the sprint times as well unless Tesla is limiting that to be easy on the older electronics, but that's a guess.
One good experiment is to use the g-force / acceleration meter in the Roadster's VDS screen. A benchmark before and after the 3.0 install with a couple of good sprints on the same leg of road would be a good test.
gregd
2,524
1,755
CM98
Great idea, but does the VDS screen have enough resolution to display such a small change (one that's not felt already)? Will it display the difference between a regular and Sport model? I think the acceleration is in the logs, however, so the VMSParser would show it. Not on my regular PC right now, so I can't check.
JRP3
Hyperactive Member
Aug 20, 2007
19,451
42,624
Central New York
I wonder if the larger pack would help 0-100 times more than 0-60. Up to 60 you should still be below the base speed of the motor where voltage sag should not have much effect. Above base motor speed pack voltage drop would become more of an issue.
ggr
Expert in Dunning-Kruger Effect!
Mar 24, 2011
6,972
27,477
San Diego, CA
I did this when I picked it up. IIRC, it showed 0.68g both before and after the upgrade. My bum-o-meter didn't feel any difference either.
Bifff67
290
26
Northern Virginia
So got call today from Rockville and sched for Oct 6. Ordered Sept 8. They say still a number of weeks for parts to get there they just wanted to book the appointment. Is there any consensus on best placement for the badge (Sport)? I did not see any pics. I'll record some numbers but not sure how to get weight simply.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
Now that some people have had the upgraded cars a short while, can anyone comment on the changes to the handling, especially if you have had the opportunity to push the car a bit on a twisty road?
