My guess is that with a 3.0 battery you could do 300 miles if you kept the speed to below 55. I am pretty confident you could not even come close to 300 miles going 70 or above.My guess is I won't be able to make that 300 real mile journey in one charge--which is what I was hoping the large battery would allow me to do.
Can't wait!From our house to yours is 288 miles. We will test that drive in February.
Damn! I have a tough time driving that slowly! Well, maybe an hour charge in Atascadero would get me there.My guess is that with a 3.0 battery you could do 300 miles if you kept the speed to below 55. I am pretty confident you could not even come close to 300 miles going 70 or above.
Um, really? 3.0 battery?The longest distance I have driven with my 3.0 battery without charging is 155 miles on a max charge and I arrived with about 70 miles of range left. I averaged around 65,mph.
There are Ideal Miles, and there are real world miles. My post was about the latter, and not with the car in Range Mode.The 3.0 battery only bought you 15 extra miles?
If I drove in Range Mode I could go farther. I hate driving in Range Mode. The car feels sluggish when I hit the Go Pedal.
Ah, ok. So Timothy can probably do just fine with a 3.0 battery on his 300 mile trip if he does it in Range mode charging and driving, and takes it just a little bit easy on the Go Pedal.There are Ideal Miles, and there are real world miles. My post was about the latter, and not with the car in Range Mode.
The user manual says it's 54 hrs to fully charge a regular battery at 120v 12a (standard 15a wall outlet). What is it for a 3.0 battery (full charge, range mode, regular wall outlet)? i.e., how long would the visit need to be in order to leave?
Yeah, I understand. But if it's all that's available, then 120v becomes really really useful. I doubt that's the case here, just a curiosity.You get about 1KW into the battery (depending on how much fan/cooling/whatever else you need), so from all the way empty to all the way full it will take the better part of 75-80 hours, or more than three days.
110V is not really all that useful.
And that is exactly what I do when I have a long drive planned.So charge in Range mode and drive in Standard mode. You get the extra charge without the power limit. That's what I usually do. Then, if you wind up needing the bottom 10% of the battery, switch back to Range.
If by "easy on the Go Pedal" you mean "lots of hard acceleration", that won't make a lot of difference. Reducing cruising speed is what makes a difference. I do not think it would be possible, on a level road with no rain or headwind, to go 300 miles in Range Mode (and starting with a full charge) at 70mph or greater. I suspect you would have keep it at 55mph or less. However, I have not personally tested that, so I am only speculating.So Timothy can probably do just fine with a 3.0 battery on his 300 mile trip if he does it in Range mode charging and driving, and takes it just a little bit easy on the Go Pedal.
Agree that the cruising speed is the major factor. My experience is that overall I can usually come close to Ideal range driving about 65 mph on the freeway, given that each end of the trip is going to be on city roads for a while at considerably slower speeds.If by "easy on the Go Pedal" you mean "lots of hard acceleration", that won't make a lot of difference. Reducing cruising speed is what makes a difference. I do not think it would be possible, on a level road with no rain or headwind, to go 300 miles in Range Mode (and starting with a full charge) at 70mph or greater. I suspect you would have keep it at 55mph or less. However, I have not personally tested that, so I am only speculating.
I bet you could squeeze out 300 miles at 60MPH, but no faster than that.If by "easy on the Go Pedal" you mean "lots of hard acceleration", that won't make a lot of difference. Reducing cruising speed is what makes a difference. I do not think it would be possible, on a level road with no rain or headwind, to go 300 miles in Range Mode (and starting with a full charge) at 70mph or greater. I suspect you would have keep it at 55mph or less. However, I have not personally tested that, so I am only speculating.
I use the same technique of charging in range mode and driving in standard mode. One (minor) problem that induces is that the battery level indication is then pegged at 100% because the battery icon range gets scaled. I calculated that for my car the fill level was effectively at 108% on the standard mode scale when the battery was fully charged in range mode.
sweetNow that we know this thread is really about "Roadster 3.0", I have renamed the thread. Again! :biggrin:
Oh and I made the thread sticky.
I neglected to include in this comment that the calculation of 108% was for my original battery. I don't know the equivalent number for the 3.0 battery yet because I don't have enough data.I calculated that for my car the fill level was effectively at 108% on the standard mode scale when the battery was fully charged in range mode.
