And 63Kwh chargableI always thought it was 56 kWh nominal and 53 kWh usable.
Well we know the roadster uses 2.2mah cells, and we know that there are 6831 of them. The rest is easy to figure out....
Maybe the 2.5 cars use the 2.4mah cells, but the early cars sure didn't. Either way, Tesla is very secretive now about what cells they use/test, so unless you personally know some top of the food chain insiders, it's all a guess.Are you sure? It's the Batteries, Stupid!
His car, or all of the cars? There are various tales of founders cars having different cells in them including the Musk cars. I have confirmation from a very valid source, that the early cars had 2.2mah cells because they were the cheapest at the time. That source no longer works at Tesla, so whatever cells they use now are pure speculation unless someone can confirm otherwise.Martin explicitly said on his blog when this topic came up (sadly now gone) that his car had 2400 mAh cells. You can't get much earlier than that.
I doubt only his car or founders cars used them.Martin sez:
Yes, I don’t know where this 2200 mAh number came from. True, in the early days of Tesla, this was state of the art. But my car is built with 2400 mAh cells, and 2600 mAh cells are the jellybean cells today. As you say, higher-capacity cells are already on the market.
That doesn't really prove the point. 100k 40-50%SOC cycles is equivalent in utility to 10k 0-100%SOC cycles. To really see if there is any gain in life from shallow cycling, A123 has to overlap that graph with battery tests for 0-100%SOC cycles with the cycles for scaled for the difference in utility.Without a doubt they under charge the cells, it's the best way to prolong their life. Limiting the finishing voltage keeps them under charged and keeps the electrolyte away from the breakdown voltage, and of course limiting the discharge cutoff voltage as well on the other end. A123 cells have tested out to 100,000 cycles by shallow cycling only between 40-50% SOC. Page 14
In THIS document, dated August, 2006, in the last paragraph of page 1, they say the pack operates at 375 volts and holds 53 kWh. But in an undated article on THIS page in the second paragraph, they say 56 kWh. That page includes a link to another article dated January, 2011, so I take it as being more recent.Well EVNow did ask the question.
In THIS document, dated August, 2006, in the last paragraph of page 1, they say the pack operates at 375 volts and holds 53 kWh....
I remember seeing a forum where a (i think) company in the US brought these dead batteries back to life by taking the battery apart and charging cells individually.
It doesn't seem likely to give a good result, but it also seems to the the only chance there is.That doesn't seem likely.
