Is the battery bricked, or does the touch screen turn on?I’m sure it has not been charged for some time
Not really since the charge connector is proprietary, but with an adapter you could use a charger with a J1772 connector.Woundering if it’s possible to make a simple charging cable?
Don’t have the car yetIs the battery bricked, or does the touch screen turn on?
PeterTesla doesn't make any adapters from Tesla2 -> Roadster, so you're looking for an aftermarket solution called the CANSR.
I have instructions I email to owners all the time for this process. In a nutshell, you apply 12V power to the APS leads in the back of the Roadster and then use the touchscreen to put the Roadster into Tow Mode. The TCM requires 12V power and a particular CAN message to unlock the parking pawl in the transmission.How to get it to roll or get out off park?
Thanks peter if you can email them to me that would be great [email protected]I have instructions I email to owners all the time for this process. In a nutshell, you apply 12V power to the APS leads in the back of the Roadster and then use the touchscreen to put the Roadster into Tow Mode. The TCM requires 12V power and a particular CAN message to unlock the parking pawl in the transmission.
Thanks PeterThanks peter if you can email them to me that would be great [email protected]
They are in front of the rear right wheel. Once the wheel and wheel arch liner are removed you will see a ground point on the side of the frame. That's where your ground lead/cable is at. It's the thickest gauge wire there. The positive lead/cable is in the small black box towards the front of the Roadster. You will see a heavy gauge wire on the right with a ring of red heat shrink, and on the left is the APS positive lead/cable which will look like your negative except it will have a ring of red heat shrink.Where do I find the APS leads in the rear
Thank you PeterThey are in front of the rear right wheel. Once the wheel and wheel arch liner are removed you will see a ground point on the side of the frame. That's where your ground lead/cable is at. It's the thickest gauge wire there. The positive lead/cable is in the small black box towards the front of the Roadster. You will see a heavy gauge wire on the right with a ring of red heat shrink, and on the left is the APS positive lead/cable which will look like your negative except it will have a ring of red heat shrink.
Let me know if you still can't find them.
That's normal. The ~12V is the pilot signal from the charger to tell the Roadster a power supply is present and ready to send power when the Roadster is ready. The two larger pins on the charger will not energize with 240V until that handshake has completed.I get 11.75 BEC on small pins and nothing on the two large pins?
You can look for a Roadster yellow spare connector. They are 120V and are usually less costly. Otherwise, the pin out for the charger is not something you want to fudge at the charge port. Open the PEM service window on the passenger side of the PEM and you will find the connections from the charge port to the PEM. Add ring terminals to your charger wires and you can tap directly into the PEM line inputs.Also right now I don’t what to spend $ for a can Dr since the car was a salvage car I’m hoping you can they’ll me the pin outs on the Tesla charge and the pin inputs on the roadster charging port?
Thank you very much for all your helpThat's normal. The ~12V is the pilot signal from the charger to tell the Roadster a power supply is present and ready to send power when the Roadster is ready. The two larger pins on the charger will not energize with 240V until that handshake has completed.
I wouldn't condone this, so tread carefully.
So peter we are talking about connecting to terminals Ac1 and Ac 2 in the set port which appear to go to charging port correct?Thank you very much for all your help
