Roadster Efficiency and Range Excel File
Discussion in 'Roadster 2008-2012' started by Yeaw, Apr 5, 2013.
Tags:
  1. Yeaw
    Yeaw New Member
    Hey everyone,
    I am working on a project for school and we are modeling the Roadster to see if a compact CVT could improve overall vehicle efficiency and performance by keeping the motor at the most efficient RPM. The drawback is that a CVT has a mechanical efficiency penalty also. On the Tesla blog, JB posted an efficiency excel file with efficiency and range graphs. I tried to use the wayback machine to get the file, but no luck.
    http://www.teslamotors.com/blog/roadster-efficiency-and-range
    Does anyone still have a copy of the efficiency excel file they could send me?
    Dan
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    • Helpful x 3
  3. Yeaw
    Yeaw New Member
    Yes it sure is, thanks for the post!
  4. dpeilow
    dpeilow Moderator
    Winchester, UK
    I would also like to get the old Excel file but @Doug_G 's link threw a 500 server error. Could you check that please (or if anyone else has it...) ?
  5. Doug_G
    Ottawa, Canada
    #5 Doug_G, Jan 23, 2017
    @dpeilow we moved to a new server. I'll fix it.
    Edit: Fixed.
  6. dpeilow
    dpeilow Moderator
    Winchester, UK
    Many thanks.
  7. gregd
    gregd Active Member
    CM98
    Wow, great resource.
    It looks like the Roadster's "Ideal" 248 mile range is based on about a 53 mi/hr speed, dropping to 200 at 65. My current battery only gets to 212 miles on a Range charge, so if the ratio holds, should I only expect a 170 mile range at freeway speeds? (248/200 * 212 = 170) Seems I did better than that when I drove 141 mostly freeway miles to the Fremont factory, arriving with about 70 miles of Ideal range left. Where did the extra 40 miles come from?
    I ask because I'm planning a trip about 20 miles farther, and that will be cutting it close if the math holds.
  8. Doug_G
    Ottawa, Canada
    When you switch to Range mode, more range magically appears. The car hides about 10% at the bottom end when it's in Standard or Performance mode.
  9. gregd
    gregd Active Member
    CM98
    Understood, but perhaps I missed something in the graphs... Are they in Standard mode, or Range mode? I assumed Range mode (seems to fit the 248 mile EPA range best). Is the difference a mismatch between EPA and Ideal? I also have assumed Ideal was based on EPA, i.e. a brand new car would Range charge to about 248 miles. No?
  10. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    When I make a drive that stretches my range, I set the dash to show estimated miles and reset the trip screen on the VDS. I also set my GPS (or phone) to track the route. That way I can see, especially as I'm getting close to half way, if I have enough estimated miles to make it to my destination without stopping to charge.
    Ideal range is based on, if I remember correctly, 230wh per mile. The trip screen also tracks wh/mile, so you can aim for that target.
    You mentioned "freeway speeds," but those can vary greatly across the country. I live off a road with an 80 or 85 mph speed limit. The long drives I make are mostly 75mph speed limits. But I have to keep the car right around 62mph to make the 204 mile trip with enough buffer to keep me calm.
    Elevation will play a huge role in your ability to make the drive. But even more so, crosswinds seem to affect range. So, always have a plan, keep and eye on progress, know your point-of-no-return, and be prepared to stop and charge if necessary.
  11. dpeilow
    dpeilow Moderator
    Winchester, UK
    The graphs are based on 55 kWh. So JB Straubel is saying the car had 55 kWh usable.
  12. Doug_G
    Ottawa, Canada
    The graphs represent the full range of the car, so they are necessarily in Range mode.
