Roadster High Power Wall Connector - SOLD
Discussion in 'Tesla Parts for Sale' started by BuyMyRoadster, Apr 25, 2015.
  1. BuyMyRoadster
    BuyMyRoadster Member
    Los Angeles, CA
    Roadster High Power Wall Connector- BRAND NEW IN BOX- NEVER USED! Retails for $1950. Fully recharges your car ? from empty to full ? in less than 4 hours.
    Model TS-70
    Technical Specs
    Max Current: 70A
    Voltage: 208-240V, Single phase
    Max Power: 16.8 kW
    Intelligent auto resettable GFCI Stationary Unit
    Cord Length: 25ft
    The TS-70 Electric Vehicle Supply Equipment (EVSE) is a conductive charge station that provides the electric vehicle user with a safe and manageable link between the power grid and the electric vehicle. The TS-70 is very easy to use.
    Installation Requirements
    Contact your electrician to determine your home?s available power (breaker rating). Your charge time is dependent on your power source. See chart below.
    Order a Home Connector and specify your home?s available power.
    OPTIONAL: Work with your electrician to upgrade your home?s power to decrease your charge time.
    Your electrician will install your Home Connector
    Hardwired into your home 240v service.
    Measures 3?3? and weighs approximately 35 pounds.
    Should be installed in a secure place on the driver?s side of the Roadster.
    Provide your electrician with the Installation Manual.
    The Tesla Roadster uses a proprietary charging connector, which is this wall-mounted 208?240 V, 70 A maximum current Home Connector from manufacturer, ClipperCreek.
    Shipping will be UPS Ground and cost depends on location it will be shipped to (approx $60-$100 based on zip code). I will only ship within USA.
    List Date: 4/26/2015
    For more info, click here to view the original listing: Roadster High Power Wall Connector
    SOLD
