Roadster Holiday Projects
Discussion in 'Roadster 2008-2012' started by drewski, Dec 23, 2019.
  1. drewski
    drewski Supporting Member
    SF Bay Area
    Have a few projects planned during my company's 1-week holiday shut-down between X-mas & New Years
    12V Secondary Battery Replacement - I'm going with the Gruber kit vs. Lithium
    LED High Beams - The Sealight bulbs recommended in this thread
    Upgraded PEM / Motor Fan & Rear Sway - Got these from a parts Roadster that was posted here since Tesla won't sell me the parts - Hopefully my fan connectors will hold up!
    Sound Reduction 0.14 - Right Front Felt Wheel Well Liner - While I'm digging around the battery & headlight thought I'd throw this in. From the same parts Roadster as the PEM fan, since, again, Tesla won't sell these to me!
    Manual Battery Cooldown Mod - Installing the LED toggle switch by the headlight switch as one person did in the thread
    JdeMO! - I'm going to try a license plate install for the inlet using some 3D printed parts from @Stefan T If you don't see posts from me in the new year, send help as I probably electrocuted myself during the install!
    • Funny x 2
  2. Logticom
    Logticom 2010 Roadster Sport | 2015 Model S 85D
    Zwolle The Netherlands
    Nice project! Good luck! I am looking forward to your updates! :)
  3. drewski
    SF Bay Area
    The manual battery cooldown mod mostly done (need to properly realign the access panel over the HVAC control unit)!
    More details here
  4. drewski
    SF Bay Area
    I removed the plastic wheel well liner prior to both the High Beam upgrade and 12V Battery replacement.
    Getting the liner out was a bit of a PITA because of how thick and non-bendable the plastic is.
    There's 3 bolts (all are M6 with 10mm heads) and one black screw (marked by the circle & hidden by the tie-rod end)
    The front has two bolts and another black plastic screw. The panel at the top is for headlight access and the one on the bottom is for 12V Aux Battery access. The battery panel will be reused with the new felt liner.
    The screws are in expanding plastic retainer things (technical term) which should be pried out as well
    What worked for me was starting at the back. First un-tucking the corner from behind the rubber mudflap (nothing mechanically securing it) and then working the outer edge under the fender lip.
    The plastic is thick and doesn't want to bend so some force is needed and some contortions help to free the inner part over the top of the shock absorber.
    Admire the fruits of your labor
    Installing the felt liner is the reverse, but comically easy in comparison, because it's infinitely more flexible
    Because the material is more flexible, the headlight panel now has 4 bolts to secure it instead of 2
  5. drewski
    SF Bay Area
  6. drewski
    SF Bay Area
    Swapped the high beam halogens for LEDs. Easy and nice upgrade in brightness. Picture below has a comparison with the stock halogen.
    More details and pictures in this thread I made
  7. drewski
    SF Bay Area
    Finished JdeMO "phase 1"
    Still thinking about behind license plate inlet location, but wanted to make sure that it actually was working!
    Few more pics here
  8. Mark77a
    Mark77a Member
    Poole, Dorset, UK
    After 9 years and 36,000, often high torque miles, mechanical sympathy got me to buy some new Gearbox oil ;) Gearbox oil.JPG
  9. drewski
    SF Bay Area
    What is the recommended interval from Tesla?
  10. drewski
    SF Bay Area
    When I was running the JdeMO harness, I also ran a backup camera wire.
