Roadster & Level-3 or ChadeMo / Supercharging?
Discussion in 'Roadster 2008-2012' started by mikecronis, Mar 12, 2016.
Tags:
  1. mikecronis
    mikecronis New Member
    Fountain, Colorado
    I have a Volt and ELR. Max-charging is 15A / 240V, so I'm stuck with the Level-2 J1772 chargers through PlugShare, etc. Here in Colorado Springs, there's some Superchargers by Tesla installed (finally!) I know that Level-3 chargers are primarily for the Model S, but I was wondering that since the adapters by Tesla are likely to be the Tesla-standard (not the J1772), what would happen if I plugged a Roadster into it? Would it work? Also, aside from the 3.0 upgrade, can a Tesla Roadster handle a ChadeMo or Direct-Current charger with an adapter?
    Don't own one yet.. looking at options. Trying to decide if the 2.0/2.5 is worth it.
  2. AEdennis
    AEdennis Active Member
    #2 AEdennis, Mar 12, 2016
    @mikecronis
    Read the forums first... No Supercharging. There is a project right now from QuickChargePower to enable up to 20 Roadsters with CHAdeMO using the JdeMO that they are developing.
    Quick charger power site - http://shop.quickchargepower.com/JdeMo-for-Tesla-Roadster-INTERESTED-OWN...
    SpeakEV.com - https://speakev.com/threads/chademo-for-tesla-roadster-quick-charge-powe...
    TMC - http://www.teslamotorsclub.com/showthread.php/55093-JdeMO-for-the-Roadster
    Hope that helps...
  3. hcsharp
    hcsharp Active Member
    Vermont
    I was hesitant to respond because I didn't want to sound like I was promoting my products (I sell adapters for the Roadster) but I may be the only person who knows the answer to your question about supercharging a Roadster using an adapter. I'm not sure what you mean by "adapters by Tesla are likely to be the Tesla-standard (not the J1772)..." J1772 is not an adapter although adapters exist to allow Tesla vehicles to use the J1772 standard. It's likely going forward that Tesla will use their TSLA02 connector (Model S/X) as the native coupler on future models. It's not likely that any other brand will adopt Tesla's proprietary coupler for a long time, if ever.
    The Roadster is not designed for DC charging (Level 3) and can't do it with just an adapter. It needs hardware modifications like the kit that Dennis mentioned being developed by Quick Charge Power. The same is true with Supercharging. If you took one of my CAN SRs (Model S/X to Roadster adapter) and plugged a Supercharger into it, nothing would happen. The Roadster would think you weren't plugged into anything, and the Supercharger would act like there was no car on the end of the cable.
  4. AEdennis
    +1 on Henry's CAN products... They're both MUST HAVE.
    Here's the review I wrote on my blog for both The Original CAN (now CAN JR for J1772 to Roadster) and The CAN SR (Model S to Roadster.) And the discussion thread of when the CAN SR was being developed.
    Henry is one of the experts with all these.
  5. TEG
    TEG Teslafanatic
    Roadster was developed before Tesla created their Supercharging system. Many people have asked Tesla to create a kit to allow Roadsters to use Superchargers, but they don't seem inclined to do so. Their Focus is on the current vehicles they sell.
    On the other hand, keep in mind that Roadster has an on-board charger that can charge at ~19kW (80AMP @ 240V), so it is probably the most capable AC medium speed charging solution of any EV that was sold. Most of the public EVSEs are only ~7kW (30A @ 240V) so it is mainly only for selected home charging that you could get those higher charge rates. There are a few places here or there with 60A or 70A J1772 that can feed a Roadster through one of Henry's "CAN" adapters.
  6. AEdennis
    @TEG, the Renault Zoe can do 43kW on 3 phase charging in the EU... And in Canada, a lot of the AC chargers on Sun Country Highway's Network that are running 70A/80A on OEM Clipper Creek CS-100 and a Roadster or Model S traveling that network can charge at max AC charging speed.
  7. TEG
    TEG Teslafanatic
    Yeah, I don't pay too much attention to the 3 phase AC charging options in Europe since I live in USA.
  8. AEdennis
    Yup... Not too much 3 phase AC for residential use around here... But interesting what other manufacturers are able to do elsewhere.
  9. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    +2 on how great Henry's adapters are! It's fabulous to be able to plug my Roadster into a Tesla HPWC at 70A.
  10. gregd
    gregd Active Member
    CM98
    ++ on Henry's adapters. I use the CAN-JR, which connects to the popular public "J1772" charging stations almost daily, and have used the CAN-SR, which connects to the original Model -S chargers (the "high power wall charger", or HPWC, not supercharger) when on a trip.
    As you probably are aware, the J1772 chargers are "Level 2", typically about 30 amps though some are higher, good for a boost during the day (while shopping, dining, etc). We have some at work, and I can do a commute round-trip's worth (60mi) of charging in just a few hours. But they're not very convenient if you're needing a full charge, which at 30A would take about 7 hrs, as the sites usually limit you to a few hour's stay (think parking time limits).
    The HPWC chargers are harder to find in the wild, but there are some around. Many but not all can charge the Roadster at its full 70A rate. Look for these at "destinations" such as Hotels and resorts. The Tesla service centers often have them as well. I'd recommend you check out the Plug-Share site (PlugShare - EV Charging Station Map - Find the nearest location to charge your electric car!) and scout around your expected driving area to see what's available.
    As for your last question, we may be a bit biased here, but is the car worth it? YES! The "Tesla Grin" comes standard, at no extra charge.
  11. AEdennis
    I added the emphasis... Please note that some of the Model S HPWC chargers in the wild may only deliver 40A or less depending on the business that installed it.
    We spent the night on a Staycation at the SLS Hotel in Beverly Hills and the Model S HPWC (which is not a part of the "official" Tesla subsidized program) that the valets use is only 40A...
    Not as helpful to the OP, but definitely for those of us that have both a Model S (or Model X) and a Roadster is that the HPWCs that show up on the navigation of the car (and on teslamotors.com find us page) is another way to find these chargers for a Roadster.
  12. DrTaras
    DrTaras R254->R725->S->X->M3->M3P-->R2020?
    Woodland Hills, CA
    Just another 'plug' (pun intended) for Henry's (hcsharp) "CAN". I have one and its an invaluable 'safety net' as is his knowledge. Whomever buys my Roadster will also inherit Henry's CAN and Martin's charging apparatus (Roadster Foundry Mobile Charger-in and of itself a collectors item). AEdennis has also provided much information to the Roadster community. But there is nobody who has more information and nobody who should be trusted more than TEG! Remember "The Wizard of Oz" and the guy behind the curtain? That's TEG! Good luck in your quest!
  13. hcsharp
    Vermont
    Many thanks for all the kind words for my adapters. DrTaras you will always be an honorary member of the Roadster community even after you sell yours. I really enjoyed your tireless enthusiasm in the early Roadster days, and if nothing else for being the only guy I know who drove his Roadster almost off a cliff, landing in the the top of a tree!;)
  14. DrTaras
    Woodland Hills, CA
    ... after all, we're JUST Tree Huggers! o_O
  15. loppy244
    loppy244 Member
    sarasota
    I actually own the CAN and absolutely love it anyone with a roadster should own one of these.
  16. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    I have both of Henry's cans and they have worked flawlessly for me. The CAN-SR does allow you to use the Tesla destination chargers many of which are 70 or 80 amps. This gives a Roadster about 60 miles per hour. So not a bad charge rate when coupled with the new 3.0 battery.
  17. bart513
    bart513 Active Member
    East Hampton
    Could you infer that those of us lucky enough to know Henry via phone, in person, TMC feel lucky that we have such an amazing member of our Roadster community. I don't see how one can have a Roadster without Henry's CAN's? Wonder what his wife would say about that?
  18. DrTaras
    Woodland Hills, CA
