I talked with some folks I know and learned a couple of things that may help bring clarity to the discussion - there are two issues under discussion here:
1) The new 3-phase wall connectors used everywhere but NA and Japan do not work with Roadsters, but a fix is eventually planned. It's the 'shared plug' issue and how aggressive the charging is. No idea on timing of the fix, but I wouldn't say it was imminent.
2) The Gen II wall connectors that don't have a shared plug (used in other places, like NA) will likely behave differently with Roadsters (but should still charge).
Basically, the behavior goes like this: Plug in, charge port stays white for maybe 10 seconds, you get an error message on the screen, then a few seconds later the charge port turns blue and the car starts charging as usual. The whole thing takes 30 seconds, tops.
Has anyone that is getting an error message (NA-only) staying plugged for ~30 seconds after the error? If that didn't work, please email the destination charging team (
[email protected]) with problem/location so Tesla knows where it is happening & they can troubleshoot.
