sometimes the error messages might lead you in a wrong direction... for example the BSM Isolation Fault can be a sign of ongoing bad isolation of an IGBT as also some moisture (for example after car wash) in the DC/DC converter under the front hood...
#905 is DMC HW: PhaseA Low Side Desat Fault meaning (as far as I know by now) that on Megapole Phase 1 Input Voltage to power ampflification has gone wrong
#906 is DMC HW: PhaseA High Side Desat Fault meaning behind IGBT (transistors) the power is lost
#909 #910 for second phase Megapole
#913 #914 for third phase
btw: it started with BSM Isolation fault and months later with #905 etc. too
#1055 #1056 are not listed but should correspond with the 905ers
As soon as my PEM has been repaired (the electronic guy promised to start soldering this week) I will make a repair thread with detailed information about the electronic parts replaced and the work been done
901 DMC HW: PhaseA OverCurrent Fault
902 DMC HW: PhaseB OverCurrent Fault
903 DMC HW: PhaseC OverCurrent Fault
904 DMC HW: Battery OverVoltage Fault
905 DMC HW: PhaseA Low Side Desat Fault
906 DMC HW: PhaseA High Side Desat Fault
907 DMC HW: PhaseA Bias Under Voltage Fault
908 DMC HW: PhaseA Bus Over voltage fault
909 DMC HW: PhaseB Low Side Desat Fault
910 DMC HW: PhaseB High Side Desat Fault
911 DMC HW: PhaseB Biad UnderVoltage fault
912 DMC HW: PhaseB Bus OverVoltage fault
913 DMC HW: PhaseC Low Side Desat fault
914 DMC HW: PhaseC High Side Desat fault
915 DMC HW: PhaseC Bias UnderVoltage fault
916 DMC HW: PhaseC Bus OverVoltage fault
