It does not charge...just makes this awful noise...Maybe one of the fans? Does it actually ramp up and charge, in spite of the noise?
Hi Steff, thanks for the reply....the noise seems to be coming from the left side of the PEM. I'll take the lid of and try and isolate where and see what's happening. This started when the megapole fuse blew some months ago...Clean the fans undre the trunk
sounds that you have some dirt i them
I had a leaf that in one that make car vibrating in high speed on the fan
Johnathan... what a nightmare!
I assume that charging didn't work and since driving seems to be possible its not the megapole boards but somewhere at AC input circuits. It could be a bad relais or a (slightly) blown capacitor. Did you also check the two fusediodes inside the connector box of the PEM?
Next step would be to take the cover of the PEM away and make a visual inspection for damaged parts....
hope it's nothing big... whats the SOC of battery meanwhile?
Greatings Daniel
left side of the PEM theres a 12V small fan inside the PEM... some cables go around this thing quite close... so maybe thats the noise that a cable gets hit by the fan... but still if the car is not charging theres another problem... does the sound only occur when trying to charge but also when in drive mode?
Then I go with a bad relais.... Get an electronic mechanic guy and open it up. If you like to make a video of the open PEM trying to charge and locating the buzz spot... also interesting would be if in drive mode it really works and not just makes the "Ding Ding" noiseOnly when it try's to charge..
Nice work, Jonathan. I think others would benefit from you posting your photos and describing your procedure so please do.
